查看: 2838|回复: 22
[求助] 使用verdi2022和verdi2023看覆盖奔溃
发表于 2025-4-23 10:35:28 | 显示全部楼层 |阅读模式
悬赏1000资产未解决
verdi -cov -covdir   {db}   奔溃,错误如下
catch signal 11 (Segmentation fault)
Thread 6 (Thread 0x7fcedb17c700 (LWP 15191)):
#0  0x00007fcee353e9fd in nanosleep () at /usr/lib64/libc.so.6
#1  0x00007fcee353e894 in sleep () at /usr/lib64/libc.so.6
#2  0x0000000002f974b3 in LicenseCheckUtility ()
#3  0x0000000006b1d2f1 in sdp_wrap_start_routine ()
#4  0x00007fcee96b2ea5 in start_thread () at /usr/lib64/libpthread.so.0
#5  0x00007fcee3577b0d in clone () at /usr/lib64/libc.so.6
Thread 5 (Thread 0x7fced51d2700 (LWP 15233)):
#0  0x00007fcee96b6de2 in pthread_cond_timedwait@@GLIBC_2.3.2 () at /usr/lib64/libpthread.so.0
#1  0x00007fcee80fc3b6 in thread_sleep(timespec*) () at /edatools/synopsys2023/verdi/V-2023.12-SP2/platform/LINUXAMD64/lib/Qt/libQtCore.so.4
#2  0x00007fcee80fcaed in QThread::msleep(unsigned long) () at /edatools/synopsys2023/verdi/V-2023.12-SP2/platform/LINUXAMD64/lib/Qt/libQtCore.so.4
#3  0x0000000005a03046 in ag::dveXThread::run() ()
#4  0x00007fcee80fd661 in QThreadPrivate::start(void*) () at /edatools/synopsys2023/verdi/V-2023.12-SP2/platform/LINUXAMD64/lib/Qt/libQtCore.so.4
#5  0x0000000006b1d2f1 in sdp_wrap_start_routine ()
#6  0x00007fcee96b2ea5 in start_thread () at /usr/lib64/libpthread.so.0
#7  0x00007fcee3577b0d in clone () at /usr/lib64/libc.so.6
Thread 4 (Thread 0x7fced45b5700 (LWP 15234)):
#0  0x00007fcee356eb43 in select () at /usr/lib64/libc.so.6
#1  0x00000000055b3c4a in NotifierThreadProc ()
#2  0x0000000006b1d2f1 in sdp_wrap_start_routine ()
#3  0x00007fcee96b2ea5 in start_thread () at /usr/lib64/libpthread.so.0
#4  0x00007fcee3577b0d in clone () at /usr/lib64/libc.so.6
Thread 3 (Thread 0x7fced1249700 (LWP 15256)):
#0  0x00007fcee353e659 in waitpid () at /usr/lib64/libc.so.6
#1  0x00007fcee34bbf62 in do_system () at /usr/lib64/libc.so.6
#2  0x00007fcee34bc311 in system () at /usr/lib64/libc.so.6
#3  0x000000000560bb3b in sysiCrash ()
#4  0x000000000560c048 in actUnexpectAction ()
#5  0x000000000560c0b2 in catchSignalCB ()
#6  0x00000000044a902f in _anrep_handler_signal ()
#7  0x00007fcee34af400 in <signal handler called> () at /usr/lib64/libc.so.6
 楼主| 发表于 2025-4-25 11:33:50 | 显示全部楼层
不是lic问题,自己解决了.谢谢大家
发表于 2025-4-23 11:35:26 | 显示全部楼层
license 问题,verdi 看覆盖率需要另外一个license
发表于 2025-4-23 11:36:24 | 显示全部楼层
license 问题,需要安装verdi看覆盖率的license
 楼主| 发表于 2025-4-23 13:45:32 | 显示全部楼层
可以分享下lic吗?谢谢
 楼主| 发表于 2025-4-23 13:51:11 | 显示全部楼层
huanghua5211 发表于 2025-4-23 13:45
可以分享下lic吗?谢谢
lic中包含了VerdiCoverage.
发表于 2025-4-23 13:55:38 | 显示全部楼层
可以分享下lic吗?谢谢
我自己没有,我只是看日志看到了
 楼主| 发表于 2025-4-23 14:00:09 | 显示全部楼层
liuyuanhuiHUST 发表于 2025-4-23 13:55
我自己没有,我只是看日志看到了
你知道缺少哪个feature吗?   lic中包含VerdiCoverage了
发表于 2025-4-23 23:43:35 | 显示全部楼层
license 问题
 楼主| 发表于 2025-4-24 07:35:37 | 显示全部楼层
nepuba 发表于 2025-4-23 23:43
license 问题
可以分享下lic,谢谢
发表于 2025-4-24 08:42:16 | 显示全部楼层
配置文件里加上export FLEXLM_DIAGNOSTICS=5,打开软件看缺少什么feature就添加
GMT+8, 2025-10-27 06:21 , Processed in 0.025199 second(s), 7 queries , Gzip On, Redis On.
