查看: 891|回复: 0
[求助] 在普通用户下安装IC618,启动InstallScape出现的问题,打开是空白
发表于 2025-4-12 14:35:36 | 显示全部楼层 |阅读模式
Type the path to InstallScape installation directory [ (q to quit)]: /home/eda/opt/cadence/iscape
InstallScape installation directory: /home/eda/opt/cadence/iscape
Extracting InstallScape version 04.23.s12
for platform lnx86 in /home/eda/opt/cadence/iscape
Starting up InstallScape in GUI mode
DISPLAY environment variable is set to :10.0
If you do not see the InstallScape console
window or it seems to be hanging then kill this
process.
Set your DISPLAY environment variable to a proper
value and manually start InstallScape by typing:
/home/eda/opt/cadence/iscape/iscape/bin/iscape.sh /home/eda/opt/cadence/IC06.18.000_lnx86.Base/CDROM1:::/home/eda/opt/cadence/IC618
Initializing InstallScape using JVM at /home/eda/opt/cadence/iscape/iscape.04.23-s012/runtime/LNX86/bin/java. This might take some time...
Error: no `server' JVM at `/home/eda/opt/cadence/iscape/iscape.04.23-s012/runtime/LNX86/lib/i386/server/libjvm.so'.
Failed with InstallScape JVM.
Now loading System JVM...
OpenJDK 64-Bit Server VM warning: You have loaded library /home/eda/opt/cadence/iscape/iscape.04.23-s012/lib/libnativemethods_lnx_64.so which might have disabled stack guard. The VM will try to fix the stack guard now.
It's highly recommended that you fix the library with 'execstack -c <libfile>', or link it with '-z noexecstack'.
求助大佬如何解决
GMT+8, 2025-10-31 23:01 , Processed in 0.012764 second(s), 3 queries , Gzip On, Redis On.
