查看: 1056|回复: 2
[求助] ERROR (CMI-2116): V0: Too few terminals given (2 < 64).
发表于 2025-4-8 23:31:50 | 显示全部楼层 |阅读模式
Warning from spectre during hierarchy flattening.
    WARNING (SPECTRE-17101): The value 'psf' specified using the 'checklimitdest' option will no longer be supported in future releases.
Error found by spectre during hierarchy flattening.
    ERROR (CMI-2116): V1: Too few terminals given (2 < 64).
Error found by spectre in `neuron_unit':`I28.I0', in `neuron_10':`I28', during hierarchy flattening.
    ERROR (CMI-2116): I28.I0.V0: Too few terminals given (2 < 64).
Error found by spectre in `neuron_unit':`I28.I9', in `neuron_10':`I28', during hierarchy flattening.
    ERROR (CMI-2116): I28.I9.V0: Too few terminals given (2 < 64).
Error found by spectre in `neuron_unit':`I28.I8', in `neuron_10':`I28', during hierarchy flattening.
    ERROR (CMI-2116): I28.I8.V0: Too few terminals given (2 < 64).
Error found by spectre in `neuron_unit':`I28.I7', in `neuron_10':`I28', during hierarchy flattening.
    ERROR (CMI-2116): I28.I7.V0: Too few terminals given (2 < 64).
Error found by spectre in `neuron_unit':`I28.I6', in `neuron_10':`I28', during hierarchy flattening.
    ERROR (CMI-2116): I28.I6.V0: Too few terminals given (2 < 64).
Error found by spectre in `neuron_unit':`I28.I5', in `neuron_10':`I28', during hierarchy flattening.
    ERROR (CMI-2116): I28.I5.V0: Too few terminals given (2 < 64).
Error found by spectre in `neuron_unit':`I28.I4', in `neuron_10':`I28', during hierarchy flattening.
    ERROR (CMI-2116): I28.I4.V0: Too few terminals given (2 < 64).
Error found by spectre in `neuron_unit':`I28.I3', in `neuron_10':`I28', during hierarchy flattening.
    ERROR (CMI-2116): I28.I3.V0: Too few terminals given (2 < 64).
Error found by spectre in `neuron_unit':`I28.I2', in `neuron_10':`I28', during hierarchy flattening.
    ERROR (CMI-2116): I28.I2.V0: Too few terminals given (2 < 64).
Error found by spectre in `neuron_unit':`I28.I1', in `neuron_10':`I28', during hierarchy flattening.
    ERROR (CMI-2116): I28.I1.V0: Too few terminals given (2 < 64).
Error found by spectre in `OTIA':`I29', during hierarchy flattening.
    ERROR (CMI-2116): I29.V0: Too few terminals given (2 < 64).
这个报错是什么意思啊  我仔仔细细检查了I28,29的电气连接  没有发现什么问题  为什么一直提到电源端子提供不足呢
 楼主| 发表于 2025-4-8 23:33:01 | 显示全部楼层
发表于 2025-6-20 14:20:12 | 显示全部楼层
这个错误是因为你有多个模块代码里面的module名字一样,但是端口数量不一样
GMT+8, 2025-12-30 23:02 , Processed in 0.015849 second(s), 5 queries , Gzip On, Redis On.
