查看: 775|回复: 4
layout识别不出mos管是什么问题
发表于 2025-3-24 19:12:00 | 显示全部楼层 |阅读模式
--------------------------- CELL COMPARISON RESULTS ( TOP LEVEL ) ---------------------------
                        ####    #####     #     #                 FAIL
LAYOUT CELL NAME=nor
SOURCE CELL NAME=nor
----------------------- HCELL ERRORS AND WARNINGS -------------------------------------------
  Error:    Numbers of instances not equal.
============================== Objects Statistic =======================================
o Before Transform
                Layout    Source         Component Type
Ports:              5         5
Nets:               5         6    *
Instances:          2         2         MN (4 pins): g (s d) b
                    12         2    *    MP (4 pins): g (s d) b
Total Inst:        14         4
       * = Object numbers are different.
o After Transform
Ports:              5         5
Nets:               5         5
Instances:          1         0    *    MN (4 pins): g (s d) b
                     1         0    *    MP (4 pins): g (s d) b
                     1         0    *    INV (2 pins)
                     0         1    *    NOR2 (3 pins)
Total Inst:         3         1
============================== INFORMATION AND WARNINGS =====================================
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:               5          5            0            0
   Nets:                5          5            0            0
   Instances:           0          0            1            0    MN(N18)
                        0          0            1            0    MP(P18)
                        0          0            1            0    INV
                        0          0            0            1    NOR2
   Total Inst:          0          0            3            1
o Statistics:
   12 layout mos transistors were merged to 2.
     10 mos transistors were deleted by parallel mergence.
o Initial Matching Nets and Instances:
   Ports:        A B VDD GND Y
发表于 2025-3-24 21:53:16 | 显示全部楼层
把布局发上来看看吧,很明显布局中的 PMOS 有问题。
发表于 2025-3-25 11:39:40 | 显示全部楼层
MOS元件的串並聯問題,可以調整相關的設定試試
 楼主| 发表于 2025-3-26 11:44:06 | 显示全部楼层
问题解决了,这是解决前的版图
原来可以无视飞线,解决后:
发表于 2025-3-28 13:35:57 | 显示全部楼层
Ohm努力干 发表于 2025-3-26 11:44
问题解决了,这是解决前的版图
原来可以无视飞线,解决后:
GMT+8, 2025-9-11 12:09 , Processed in 1.026852 second(s), 4 queries , Gzip On, Redis On.
