查看: 983|回复: 1
metaware mx软件报告:Checkout denied SeeCode 8.9
发表于 2025-3-17 21:36:03 | 显示全部楼层 |阅读模式
license文件里有这个feature,log里没有任何checkout/checkin的提示。用pubkey/FlexNetLicensePatcher/SynopsysMonoSlayer都试过了。其它feature正常。
[SCL] SCL trace is enabled.
FlexNet Licensing checkout error: License server machine is down or not responding.
See the system administrator about starting the license server system, or
make sure you're referring to the right host (see LM_LICENSE_FILE).
Feature:       SeeCode
Hostname:      icserver
License path:  27406@icserver:16661@icserver:5216@icserver:/mnt/hgfs/e/Xilinx/xilinx.dat:3230@icserver:/opt/tools/license/matlab.lic:
FlexNet Licensing error:-96,7.  System Error: 16 "Device or resource busy"
license file(s):  27406@icserver 16661@icserver 5216@icserver /mnt/hgfs/e/Xilinx/xilinx.dat 3230@icserver /opt/tools/license/matlab.lic
[SCL] 03/17/2025 21:23:07 PID:13050 Client:icserver Checkout denied SeeCode 8.9
[SCL] 03/17/2025 21:23:07 PID:13050 Client:icserver checkin (null)
There is an error with your license server configuration.
Check that SNPSLMD_LICENSE_FILE env using ( as a delimiter.
Check that multiple lmgrd servers are not running on your host.
Check that the vendor daemon was started correctly. See the
log file that was entered when lmgrd was started for details.
Try shutting down all lmgrd processes and starting a new one.
Check the host process manager for multiple running lmgrd processes.
Error text from License Manager:
License file(s) considered:
    27406@icserver
    16661@icserver
    5216@icserver
    3230@icserver
Licensing DLL version: SDK_12.11.10
发表于 2025-3-17 22:00:41 | 显示全部楼层
那就是license问题了。
GMT+8, 2025-12-24 10:53 , Processed in 0.013015 second(s), 4 queries , Gzip On, Redis On.
