查看: 2176|回复: 5
[求助] 求助各位大佬,TSMC180工艺库安装报错
发表于 2025-3-5 21:56:38 | 显示全部楼层 |阅读模式
悬赏500资产未解决
    Cadence版本为IC618,安装的TSMC工艺库为Cadence OA版本,具体名为“t018cmsp018k3_1_0a”。
    工艺库内部截图:
    在此文件夹中打开终端运行“perl pdkInstall.pl”后根据工艺库提示文件定义参数安装,最终命名安装文件名时会报如下图的错误:
    具体的报错代码放在2楼
 楼主| 发表于 2025-3-7 17:48:21 | 显示全部楼层
    最终发现问题出现在运行安装脚本“pdkInstall.pl”文件的目录中有空格(其中一个文件夹叫Cadence OA),将空格改为下划线即可成功安装。
    此贴完结。
 楼主| 发表于 2025-3-5 22:00:36 | 显示全部楼层
下面是具体的报错代码:
[****@cryocmoseda t018cmsp018k3_1_0a]$ perl pdkInstall.pl
       - TSMC Process Ddesign Kit (PDK) Install Utility V1.0a -
    This perl script is used to install TSMC PDKs from the directory that
contains the original distribution source files (a super-set of PDKs) to a
specified destination directory according to the user specified options.
*Avaliable types of MIM cap are:
   1 - 1.0fF
   2 - 2.0fF
Please enter your choice: (1,2...)
2
*Avaliable choices are:
   1 - 1P6M_4X1U(20K UTM)
   2 - 1P5M_3X1U(20K UTM)
   3 - 1P4M_2X1U(20K UTM)
   4 - 1P6M_4X1U(40K UTM)
   5 - 1P5M_3X1U(40K UTM)
   6 - 1P4M_2X1U(40K UTM)
4
Please enter your Installation Directory Name(Not Directory path):
/home/****/Cadence/PDK/tsmc18
Please confirm with your selection :
*** Select mimcap : 2.0fF
*** Select package : 1P6M_4X1U(40K UTM)
*** Install to directory : /home/****/Cadence/PDK/tsmc18
Are these correct (y|n) ?
y
====== Unpacking tar files ======
>>> Unpacking tsmc18_lib.tar.gz ......gzip: /home/****/PDK/Cadence.gz: No such file or directory
gzip: OA/t018cmsp018k3_1_0a/tsmc18_lib.tar.gz: No such file or directory
tar: This does not look like a tar archive
tar: Exiting with failure status due to previous errors
Untar package fail - tsmc18_lib.tar.gz !!!
发表于 2025-5-20 09:21:36 | 显示全部楼层
哥们你是怎么找到tsmc18的库的,为毛我看了半天只有tsmc18rf的库
发表于 2025-6-27 17:40:52 | 显示全部楼层
对啊我也很好奇怎么找到的18,我找的全是18rf的
发表于 2025-8-1 16:23:44 | 显示全部楼层
目录有()括号也不行
GMT+8, 2025-12-17 01:16 , Processed in 0.190514 second(s), 6 queries , Gzip On, Redis On.
