楼主: nemenis
关于新版本Calibre集成到Cadence中脚本的问题请教
发表于 2025-5-23 11:40:36 | 显示全部楼层
; check CALIBRE_HOME
cal_home=getShellEnvVar("CALIBRE_HOME")
if( cal_home==nil then
    cal_home=getShellEnvVar("MGC_HOME")
    if( cal_home!=nil then
        printf("// CALIBRE_HOME environment variable not set; setting it to value of MGC_HOME\n");
if( cal_home!=nil && isDir(cal_home) && isReadable(cal_home) then
    if( getShellEnvVar("MGC_CALIBRE_REALTIME_VIRTUOSO_ENABLED") &&
        getShellEnvVar("MGC_REALTIME_HOME") && dbGetDatabaseType()=="OpenAccess" then
      setSkillPath(append1(getSkillPath() strcat(getShellEnvVar("MGC_REALTIME_HOME") "/lib")))
    else
      setSkillPath(append1(getSkillPath() strcat(cal_home "/lib")))
    ; Load calibre.skl or calibre.4.3.skl, not both!
    ; Load calibre.skl for Cadence versions 4.4 and greater
    load("calibre.skl")
;;; Load calibre.4.3.skl for Cadence version 4.3
;;; load("calibre.4.3.skl")
else
    ; CALIBRE_HOME is not set correctly. Report the problem.
    printf("//  Calibre Error: Environment variable ")
    if( cal_home==nil || cal_home=="" then
        printf("CALIBRE_HOME is not set.");
    else
        if( !isDir(cal_home) then
            printf("CALIBRE_HOME does not point to a directory.");
        else
            if( !isReadable(cal_home) then
                printf("CALIBRE_HOME points to an unreadable directory.");
    printf(" Calibre Skill Interface not loaded.\n")
    ; Display a dialog box message about load failure.
    hiDisplayAppDBox(
        ?name           'MGCHOMEErrorDlg
        ?dboxBanner     "Calibre Error"
        ?dboxText       "Calibre Skill Interface not loaded."
        ?dialogType     hicErrorDialog
        ?dialogStyle    'modal
        ?buttonLayout   'Close
GMT+8, 2025-12-21 10:10 , Processed in 0.140185 second(s), 3 queries , Gzip On, Redis On.
