查看: 2302|回复: 6
synopsys lic 问题
发表于 2025-2-19 11:51:45 | 显示全部楼层 |阅读模式
11:37:00 (lmgrd) snpslmd exited with status 255 ()
11:37:00 (lmgrd) Since this is an unknown status, license server
11:37:00 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
11:37:00 (lmgrd) Starting vendor daemon at port 28300
11:37:00 (lmgrd) Using vendor daemon port 28300 specified in license file
11:37:00 (lmgrd) REStarted snpslmd (internet tcp_port 28300 pid 357811)
11:37:00 (snpslmd) FlexNet Licensing version v11.19.4.1 build 291070 x64_lsb
02/19/2025 11:37:02 (snpslmd) INFO: Pooling on VENDOR_STRING is Disabled (to enable, set SCL_POOL_VS=1)
02/19/2025 11:37:02 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_2023.09
02/19/2025 11:37:05 (snpslmd) INFO: License sanity check enabled (3600)
02/19/2025 11:37:05 (snpslmd) INFO: File descriptor limit (soft, hard) for snpslmd: 1048576, 1048576
02/19/2025 11:37:05 (snpslmd) INFO: TCP - tcp_keepalive_time - 7200 | tcp_keepalive_intvl - 75 | tcp_keepalive_probes - 9 | tcp_fin_timeout - 60 | net.ipv4.tcp_max_syn_backlog=2048 | net.core.somaxconn=10000
02/19/2025 11:37:05 (snpslmd) INFO: Cloud detection enabled. 1
11:37:05 (snpslmd) SLOG: Summary LOG statistics is enabled.
11:37:05 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT1
11:37:05 (snpslmd) SLOG: VM Status: 0
11:37:05 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT5
11:37:05 (snpslmd) SLOG: TPM Status: 0
11:37:05 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT6
11:37:05 (snpslmd) CVD License file has been Tampered.So no.of license Restricted to Original count
请问为什么启动的到最后阶段报这个错误?如何解决呀
发表于 2025-2-19 14:16:06 | 显示全部楼层
我的也有,不过后面没问题
发表于 2025-2-19 15:10:14 | 显示全部楼层
why?
发表于 2025-2-20 18:56:06 | 显示全部楼层
see see
发表于 2025-3-25 15:49:31 | 显示全部楼层
scl太细了
发表于 2025-7-22 23:13:52 | 显示全部楼层
我也遇到相同问题 ,怎么解决呀
发表于 2025-7-22 23:24:47 | 显示全部楼层
Wershner 发表于 2025-7-22 23:13
我也遇到相同问题 ,怎么解决呀
持有有效执照
GMT+8, 2025-11-7 04:53 , Processed in 0.018892 second(s), 5 queries , Gzip On, Redis On.
