查看: 4032|回复: 18
synopsys 2024 key gen please
发表于 2025-2-1 16:38:51 | 显示全部楼层 |阅读模式
Can pay you ... $$$
somni
发表于 2025-2-1 17:39:59 | 显示全部楼层
Can be solved
发表于 2025-2-1 20:37:08 | 显示全部楼层
If you have applied patch to SNPS products, you dont need a keygen to generate the license file. Just follow the license file format and add new FEATURE or INCREMENT lines. The SIGN keyword wont be checked.
 楼主| 发表于 2025-2-2 12:23:11 | 显示全部楼层
 楼主| 发表于 2025-2-2 12:25:33 | 显示全部楼层
xbwpc 发表于 2025-2-1 20:37
If you have applied patch to SNPS products, you dont need a keygen to generate the license file. Jus ...
I don't have a patch file for 2024.09 software.
it is better have keygen, than I can make new key when updates are available ....
somni
发表于 2025-2-2 18:07:47 | 显示全部楼层
what kind of patch?   is it safe or may be embedded with some trojans?
发表于 2025-2-2 18:17:29 | 显示全部楼层
Patched versions of 2024.09 tools(syn and primetime) with patched scl 2024.06 gave error: License server system does not support this version of this feature.
发表于 2025-2-2 18:18:33 | 显示全部楼层
发表于 2025-2-2 18:24:39 | 显示全部楼层
发表于 2025-2-2 18:25:26 | 显示全部楼层
GMT+8, 2025-12-14 15:31 , Processed in 0.017443 second(s), 3 queries , Gzip On, Redis On.
