查看: 720|回复: 0
[求助] icc2流程中eco fusion问题
发表于 2024-12-12 16:03:55 | 显示全部楼层 |阅读模式
大佬们,根据icc2手册做到eco fusion这一步的时候,调用starrc和pt报错,不知道如何解决
Compatibility:
  - IC Compiler II: O-2018.06-SP2-BETA (Schema revision: 1.235)
                                  StarRC (TM)
               Version O-2018.06-SP1 for linux64 - Jul 19, 2018
                    Copyright (c) 1999 - 2018 Synopsys, Inc.
   This software and the associated documentation are proprietary to Synopsys,
Inc. This software may only be used in accordance with the terms and conditions
of a written license agreement with Synopsys, Inc. All other use, reproduction,
            or distribution of this software is strictly prohibited.
ExecName: /home/synopsys/Starrc/starrc/O-2018.06-SP1/linux64_starrc/bin/StarXtract
Version: O-2018.06-SP1
Built on: Jul 19 2018 21:37:47
Start Time: Thu Dec 12 15:58:21 2024
Host ............ IC_EDA
ERROR: Host IC_EDA supports both IPv4 and IPv6 internet protocol addressing. Use the ENABLE_IPV6
       option to specify the addressing mode to be used by StarRC for distributed processing. (SX-3684)
Error: starrc_extract_rc failed: StarRC is failed to generate GPD/home/ICer/Documents/ICC2_BLI_2018.06-SP4/lab9_11_route_signoff/work_dir/ORCA_TOP_design_files.4261387727/ORCA_TOP_StarRC_route_auto.gpd. (NEX-054)
### FMT-DESIGN: Error! Failure with Parasitics generation!
Warning: Block 'ORCA_TOP' has no frame view with empty label, will ignore it. (LEFW-005)
Warning: Use defaultWidth 0.05 as the WRONGDIRECTION width for layer 'M1'. (LEFW-007)
Warning: Use defaultWidth 0.056 as the WRONGDIRECTION width for layer 'M2'. (LEFW-007)
Warning: Use defaultWidth 0.056 as the WRONGDIRECTION width for layer 'M3'. (LEFW-007)
Warning: Use defaultWidth 0.056 as the WRONGDIRECTION width for layer 'M4'. (LEFW-007)
Warning: Use defaultWidth 0.056 as the WRONGDIRECTION width for layer 'M5'. (LEFW-007)
Warning: Use defaultWidth 0.056 as the WRONGDIRECTION width for layer 'M6'. (LEFW-007)
Warning: Use defaultWidth 0.056 as the WRONGDIRECTION width for layer 'M7'. (LEFW-007)
Warning: Use defaultWidth 0.056 as the WRONGDIRECTION width for layer 'M8'. (LEFW-007)
Warning: Use defaultWidth 0.16 as the WRONGDIRECTION width for layer 'M9'. (LEFW-007)
Warning: Use defaultWidth 2 as the WRONGDIRECTION width for layer 'MRDL'. (LEFW-007)
Report : Data Mismatches
Date   : Thu Dec 12 15:58:24 2024
No mismatches exist on the design.
Number of Written DEF Constructs
VERSION                        : 1
DIVIDERCHAR                    : 1
BUSBITCHARS                    : 1
DESIGN                         : 1
UNITS                          : 1
DIEAREA                        : 1
ROW                            : 455
TRACKS                         : 20
VIAS                           : 74
NONDEFAULTRULES                : 3
COMPONENTS                     : 54108
PINS                           : 240
SPECIALNETS                    : 30992
NETS                           : 56899
SCANCHAINS                     : 8
### FMT-DESIGN: Information! Found '4' scaling-groups in scenario 'func.ff_125c'...
### FMT-DESIGN: Information! Found '4' scaling-groups in scenario 'func.ff_m40c'...
### FMT-DESIGN: Information! Found '4' scaling-groups in scenario 'func.ss_125c'...
### FMT-DESIGN: Information! Found '4' scaling-groups in scenario 'test.ff_125c'...
### FMT-DESIGN: Information! Found '4' scaling-groups in scenario 'test.ss_125c'...
### FMT-DESIGN: Disable 'setup' analysis of scenario 'func.ff_125c' due to 'set_scenario_status'!
### FMT-DESIGN: Disable 'setup' analysis of scenario 'func.ff_m40c' due to 'set_scenario_status'!
### FMT-DESIGN: Disable 'hold' analysis of scenario 'func.ss_125c' due to 'set_scenario_status'!
### FMT-DESIGN: Disable 'setup' analysis of scenario 'test.ff_125c' due to 'set_scenario_status'!
### FMT-DESIGN: Disable 'hold' analysis of scenario 'test.ss_125c' due to 'set_scenario_status'!
### FMT_DESIGN: DMSA-script will be ignored in current release.
### FMT-DESIGN: Completed with result = '-1'.
Error: 0
Error: Failed to generate PrimeTime run files
Error: Failed to execute eco_opt
        Use error_info for more info. (CMD-013)
GMT+8, 2025-12-24 21:20 , Processed in 2.372113 second(s), 4 queries , Gzip On, Redis On.
