查看: 1422|回复: 6
[求助] 找書: Minimum Number of Timing Signoff Corners
发表于 2024-12-11 23:34:11 | 显示全部楼层 |阅读模式
找書:
書名:  Minimum Number of Timing Signoff Corners
作者 [color=var(--__N4QdChsbGN6j,#007185)]Dr. Alexander Tetelbaum (Author)
Abstract
This unique book describes a brand new approach of how to do timing signoff of complex microchips and Systems-on-Chip (SoC) with the minimum number of corners. The number of timing signoff corners exponentially grows and makes microchip design very complex, time consuming, or even impossible to close timing. Additionally, there is a toll on microchip performance due to conservatism, which increases with the corner number.
Factors impacting the corner number and methods on how to find the minimum number of traditional Power, Voltage, Temperature (PVT) and Resistance, Capacitance (RC) corners are considered. A break-through method with the absolute minimum of the corner number is justified where instead of PVT/RC corners 4 min/max timing delay corners (so-called slack corners) are introduced.
Also a new approach on how to design SoC for the maximum profit by setting a proper target for the timing yield Y during timing signoff is discussed. Finally, possible enhancements in signoff paradigms, methods, and statistical STA tools are outlined. The importance of these pseudo- and fully-statistical Monte Carlo-based post-STA methods is to study OCV variations in detail and justify all OCV derates for STA tools no matter the PVT/RC corners signoff is or the 4-slack corners is used.
The book is mainly targeting microchip designers and software engineers in Electronic Design Automation (EDA) companies as well as companies that design and/or manufacture microchips.
发表于 2024-12-12 08:38:02 | 显示全部楼层
下载看看
发表于 2024-12-12 08:39:55 | 显示全部楼层
没有附件?
发表于 2024-12-12 13:33:09 | 显示全部楼层
timing signoff是啥啊?
发表于 2024-12-12 13:52:01 | 显示全部楼层
好书, 有大佬分享吗?
发表于 2024-12-12 14:04:15 | 显示全部楼层
亚马逊上有卖的,但很贵!!!!!
发表于 2024-12-18 08:41:30 | 显示全部楼层
估计难找
GMT+8, 2025-12-28 09:51 , Processed in 0.019461 second(s), 4 queries , Gzip On, Redis On.
