楼主: 天涯羁客
cadence 配置分布式计算
发表于 2024-12-10 10:27:53 | 显示全部楼层
sea11038 发表于 2024-12-9 12:16
普通的tran仿真
、谢谢!
发表于 2024-12-10 11:32:47 | 显示全部楼层
i guess u need dispatch mpi job via farm
发表于 2024-12-10 20:29:56 | 显示全部楼层
chuchuang 发表于 2024-12-10 10:27
图片里的选项 怎样设置可以一个仿真 分成几个机器跑  发下你的设置 谢谢!
服务器集群类型不同设置方法可能不同,这个UI我没用过,好像是较旧的APS的dp吧?我是在LSF下设置或直接命令行运行spectreX的xdp
发表于 2024-12-10 20:38:55 | 显示全部楼层
APS仿真器上限64核,可能用分布式仿真的意义不大。Spectre X上限512核,对于大规模电路采用分布式仿真更有意义。
发表于 2024-12-10 21:33:33 | 显示全部楼层
sea11038 发表于 2024-12-10 20:29
服务器集群类型不同设置方法可能不同,这个UI我没用过,好像是较旧的APS的dp吧?我是在LSF下设置或直接命 ...
谢谢
发表于 2024-12-10 22:12:42 | 显示全部楼层
chuchuang 发表于 2024-12-10 21:33
发一下提交指令 和使用命令  回头请人测试下 谢谢
因涉及非公开信息,原贴已删除,下述内容来自spectre用户手册,侵删:
You can use the following command to distribute a job locally using rsh across two hosts, hostA and hostB (with each host using 16 cores):
% spectre +preset=mx +mt=16 +xdp=rsh +hosts "hostA:1 hostB:1" /hm/test/input.scs
Note: The specified path, for example, /hm/test/input.scs, should be network accessible.
If you need to use ssh instead of rsh, you must specify the ssh argument with the +xdp option; however, the +hosts argument may remain unchanged.
% spectre +preset=mx +mt=16 +xdp=ssh +hosts "hostA:1 hostB:1" /hm/test/input.scs
In the LSF use model, it is assumed that Spectre X is started using the LSF job submission command or a user-specific wrapper. Spectre X automatically detects this and queries LSF for a list of hosts allocated to the job by LSF and the number of cores allocated on each host. Add the +xdp command-line option only without +mt to ensure that distributed mode is started.
In the following example, the bsub command is used to request a total of 32 cores, on two machines, with 16 cores on each machine. Spectre X automatically uses the allocated cores and machines supplied by LSF.
% bsub -n 32 -q rnd -P myProject -R "OSREL==EE70 && CPUS>=16 span[ptile=16]" spectre +preset=mx +xdp /hm/test/input.scs
If you want to use SGE instead of LSF, you can use the following equivalent command:
% qsub -l nodes=2,ppn=1,tpp=16 -V -cwd "spectre +preset=mx +xdp /hm/test/input.scs
If you want to use PBS instead of LSF, you can use the following equivalent command:
% qsub -l select=2:ncpus=16 -q rnd -P myProject "spectre +preset=mx +xdp /hm/test/input.scs
GMT+8, 2025-12-13 07:43 , Processed in 0.016424 second(s), 3 queries , Gzip On, Redis On.
