查看: 1062|回复: 7
[求助] 锁相环的LOCK侦测模块,有VerilogA代码或者文章参考吗。
发表于 2024-10-31 12:13:21 | 显示全部楼层 |阅读模式
头疼。
发表于 2024-10-31 12:50:17 | 显示全部楼层
`include "disciplines.vams"  module pll_lock_detector(input phase_difference, output reg lock);      // Parameters     parameter real threshold = 0.1;  // Threshold for determining lock     parameter real check_time = 1e-6; // Time window to check for lock     parameter real hysteresis = 0.05; // Hysteresis for lock determination      // Internal signals     real phase_diff_integrated;     real time_count;      analog begin         @(initial_step) begin             phase_diff_integrated = 0;             time_count = 0;             lock = 0;         end          // Integrate phase difference over time         phase_diff_integrated = phase_diff_integrated + abs(phase_difference) * `dt;         time_count = time_count + `dt;          // Check if phase difference is within threshold         if (time_count >= check_time) begin             if (phase_diff_integrated <= threshold) begin                 lock = 1;             end else if (phase_diff_integrated >= threshold + hysteresis) begin                 lock = 0;             end             // Reset integration and time counter             phase_diff_integrated = 0;             time_count = 0;         end     end endmodule
发表于 2024-10-31 12:53:14 | 显示全部楼层
    // Parameters
    // Internal signals
    real time_count;
    analog begin
            time_count = 0;
            lock = 0;
        end
                lock = 1;
                lock = 0;
            end
            time_count = 0;
        end
    end
endmodule
In this code:
phase_difference: The input signal representing the phase difference between the reference signal and the output signal of the PLL.
lock: The output signal indicating whether the PLL is locked or not.
threshold: The phase difference threshold used to determine if the PLL is locked.
check_time: The time window over which the phase difference is integrated.
hysteresis: The additional threshold margin to prevent oscillation around the lock state.
This lock detector works by integrating the absolute phase difference over a specified time window and comparing it against a threshold. If the integrated phase difference is below the threshold, it indicates that the PLL is locked. The hysteresis parameter helps prevent the lock signal from rapidly toggling due to small fluctuations.
发表于 2024-10-31 12:54:56 | 显示全部楼层
    // Parameters
    // Internal signals
    real time_count;
    analog begin
            time_count = 0;
            lock = 0;
        end
                lock = 1;
                lock = 0;
            end
            time_count = 0;
        end
    end
endmodule
In this code:
发表于 2024-10-31 13:36:24 | 显示全部楼层
有吗 ?  只有看一些datasheet上有描述,同求
 楼主| 发表于 2024-11-1 08:48:30 | 显示全部楼层
感谢
 楼主| 发表于 2024-11-1 08:49:17 | 显示全部楼层
好的,感谢~
 楼主| 发表于 2024-12-22 10:05:14 | 显示全部楼层
实测不能运行。。。
GMT+8, 2025-12-19 15:19 , Processed in 0.017115 second(s), 3 queries , Gzip On, Redis On.
