各位大佬,ads软件仿真模型不会看,到底要怎样建立模型呐
SD2933 - 资源 - Search STMicrocontrollers 这个ads模型
*SD2941-10 Vgs=3.2V Vdd=50V Ids=246 mA. RF 30 - 230 MHz.
* Vertical DMOS , Low Rds(on) process patent numbers US6750512,EP1296378
*Large Signal Model REVISION 2 jprit April 28 2005
*STMicroelectronics
*RF Product Development and Characterization
*Malvern ,PA,USA
*node 10 = Gate
*node 20 = Drain
.SUBCKT sd2941/10 20 10 30
lg 10 11 0.3N
rg 11 12 0.2
cg 10 30 0.01P
crss 12 17 19P
ciss 12 14 460P
Ls 14 30 0.4N
cs 14 30 0.02P
ld 17 20 .1N
cd 20 30 0.02P
cdrain 14 17 20P
MOS 13 12 14 14 pps1941 L=2.0u w=0.700
JFET 17 14 13 pps1941j
DBODY 14 17 pps1941d
.MODEL pps1941 nmos (vto=3 KP=0.9E-5 LAMBDA=0.5 RD=0.03 RS=0.02)
.MODEL pps1941j njf (VTO=-6.5 BETA=.05 LAMBDA=3)
.MODEL pps1941d d (CJO=1500p RS=0.25 VJ=0.6 M=0.4 BV=142)
.ENDS
看不懂,在ads中都没找到在哪里设置这些模型参数
