查看: 2792|回复: 16
[求助] 求助SKILL 运行报can't handle (floatStruct......)问题!!
发表于 2024-10-20 23:14:06 | 显示全部楼层 |阅读模式
      在创建一个shielding path的菜单初步阶段,简化找到问题的代码段。发现菜单和运行主函数相互交互过程中,一直报所定义的获取菜单内输入数值赋予的变量,它的类型不对的问题?!debug了下找不原因在哪?代码和问题图示如下:
如图中所示,通过printf发现是在报mainPathWidth 和 subPathWidth  这类变量是floatStruct的这种类型格式,无法进行计算。不知是什么原因?麻请大佬们指教!谢谢!
;load testChoiceMode.il
procedure(makeThree()
    myAppForm ~> choiceType ~> value == "Three"
    threeLayerShielding()
    pathRadioField_CB(1)
);end proc
procedure(makeTwo()
    myAppForm ~> choiceType ~> value == "Two"
    twoLayerShielding()
    pathRadioField_CB(2)
);end proc
procedure(testChoiceModeForm()
    let((myAppForm)
        choiceType = hiCreateRadioField(
            ?name 'mppType
            ?choices list("Three" "Two")
            ?defValue "Three"
            ?prompt " "
            ?callback list("makeThree()" "makeTwo()")
        );end choice
    layer1 = hiCreateCyclicField(
        ?name 'layer1
        ?prompt "layer1"
        ?value "METAL1"
        ?enabled t
        ?choices list("METAL1" "METAL2" "METAL3" "METAL4")
    );end upLayerName
    layer2 = hiCreateCyclicField(
        ?name 'layer2
        ?prompt "layer2"
        ?value "METAL2"
        ?enabled t
    );end middleLayerName
    mainPathWidth = hiCreateFloatField(
        ?name 'mainPathWidth
        ?prompt "Main layer width"
        ?value 0.38
        ?defValue 0.38
        ?range '(0.38 5.0)
        ?editable t
    );end mainPathWidth
    subPathWidth = hiCreateFloatField(
        ?name 'subPathWidth
        ?prompt "Sub layer width"
        ?value 0.38
        ?defValue 0.38
        ?range '(0.38 5.0)
        ?editable t
    );end mainPathWidth
    separa = hiCreateSeparatorField(?name 'separa)
    myAppForm = hiCreateAppForm(
        ?name   'myAppForm
        ?formTitle  "createCustomerPathMpp"
        ?fields list(choiceType mainPathWidth subPathWidth layer1 layer2 separa)
        ?callback list("createMppCB()")
        ?buttonLayout 'OKCancelApply
    );end myAppForm
    hiDisplayForm('myAppForm)
    );end let
);end proc
procedure(createMppCB()
let((layer1 layer2)
        mainPathWidth = myAppForm ~> mainPathWidth ~> value
        subPathWidth  = myAppForm ~> subPathWidth ~> value
        layer1 = myAppForm ~> layer1 ~> value
        layer2 = myAppForm ~> layer2 ~> value
    );end let
);end proc
procedure(pathRadioField_CB(radio)
    if(radio == 1 then
        myAppForm ~> layer1 ~> enabled = t
        myAppForm ~> layer2 ~> enabled = t
        myAppForm ~> layer2 ~> invisible = nil
    else
        myAppForm ~> layer2 ~> invisible = t
    );end if
);end procedure
procedure(threeLayerShielding()
    let((three)
        three = 3
        printf("%d\n" three)
        t3a = mainPathWidth + 1
        t3b = subPathWidth + 1
        printf("t3a = %L t3b = %L" t3a t3b)
    );end let
);end proc
procedure(twoLayerShielding()
    let((two)
        two = 2
        printf("%d\n" two)
        t2a = mainPathWidth + 1
        t2b = subPathWidth + 1
        printf("t2a = %L t2b = %L" t2a t2b)
    );end let
);end proc
hiSetBindKey("Layout" "Shift<Key>h" "testChoiceModeForm()")
发表于 2024-10-20 23:37:56 | 显示全部楼层
代码中:
  1. t3a = mainPathWidth + 1
  2. t3b = subPathWidth + 1
    复制代码
改成:
  1. t3a = mainPathWidth~>value + 1
  2. t3b = subPathWidth~>value + 1
    复制代码
就可以了
 楼主| 发表于 2024-10-21 05:51:49 来自手机 | 显示全部楼层
谢谢!我再试下!
 楼主| 发表于 2024-10-21 09:34:05 | 显示全部楼层
amodaman 发表于 2024-10-20 23:37
代码中:
改成:
再请教下,为什么这里已经赋值mainPathWidth = myAppForm ~> mainPathWidth ~> value,但在主函数中还要再额外给于赋值下?谢谢~
发表于 2024-10-21 10:14:37 | 显示全部楼层
你梳理一下数据流的走向,就知道,你的主函数threeLayerShielding()和twoLayerShielding() 并没有主动去调用GUI myAppForm这部分, 你是依靠myAppForm预先在内存里面先初始化了之后,再产生了全局变量 mainPathWidth。 所以这是两段分离的程序。要连接在一起,需要在threeLayerShielding()和twoLayerShielding() 中调用GUI这部分。
 楼主| 发表于 2024-10-21 11:54:34 | 显示全部楼层
谢谢!
发表于 2024-10-21 12:56:52 | 显示全部楼层
其实改起来也很简单
1)先把myAppForm这个局部变量的声明去掉,其实作为一个好习惯,所有的GUI都不应该成为局部变量。 你想想看,作为一个可以操作到的GUI, 设置成局部变量会有非常不方便的地方,没什么明显的好处。GUI就是全局。
2)在你的两个主函数 makeThree()和makeTwo()的第一行,增加一句
  1. testChoiceModeForm()
    复制代码
代码改动和运行结果如图所示:
发表于 2024-10-21 13:39:27 | 显示全部楼层
 楼主| 发表于 2024-10-21 14:22:41 | 显示全部楼层
amodaman 发表于 2024-10-21 12:56
其实改起来也很简单
1)先把myAppForm这个局部变量的声明去掉,其实作为一个好习惯,所有的GUI都不应该成 ...
感谢!!感谢!!刚又试下,但在我这运行后,还是会报下can't handle的ERROR,还报了myAppForm的warning。myAppForm那个变量赋值位置需要做什么处理么?!
图1
图1
图2
图2
 楼主| 发表于 2024-10-21 14:30:48 | 显示全部楼层
YuSHL 发表于 2024-10-21 13:39
https://bbs.eetop.cn/thread-971422-1-1.html
谢谢!同步也参考下!
GMT+8, 2025-10-26 03:53 , Processed in 0.019776 second(s), 5 queries , Gzip On, Redis On.
