查看: 1308|回复: 2
数字后端新手 请问这问题出在哪里
发表于 2024-9-21 13:41:52 | 显示全部楼层 |阅读模式
悬赏200资产未解决
innovus 19> init_design
#% Begin Load MMMC data ... (date=09/21 13:25:50, mem=557.7M)
/home/ic_eda/dh6_innovus/library/liberty/MEM1_256X32_slow.lib: line 1: /bin: Is a directory
/home/ic_eda/dh6_innovus/library/liberty/MEM1_256X32_slow.lib: line 2: data: command not found
/home/ic_eda/dh6_innovus/library/liberty/MEM1_256X32_slow.lib: line 3: data: command not found
/home/ic_eda/dh6_innovus/library/liberty/MEM1_256X32_slow.lib: line 4: data: command not found
/home/ic_eda/dh6_innovus/library/liberty/MEM1_256X32_slow.lib: line 5: data: command not found
/home/ic_eda/dh6_innovus/library/liberty/MEM1_256X32_slow.lib: line 6: data: command not found
/home/ic_eda/dh6_innovus/library/liberty/MEM1_256X32_slow.lib: line 7: data: command not found
/home/ic_eda/dh6_innovus/library/liberty/MEM1_256X32_slow.lib: line 8: data/: Is a directory
/home/ic_eda/dh6_innovus/library/liberty/MEM1_256X32_slow.lib: line 10: syntax error near unexpected token `MEM1_256X32'
/home/ic_eda/dh6_innovus/library/liberty/MEM1_256X32_slow.lib: line 10: `library(MEM1_256X32) {'
child process exited abnormally
发表于 2024-9-22 14:11:20 | 显示全部楼层
用vim打开/home/ic_eda/dh6_innovus/library/liberty/MEM1_256X32_slow.lib 看下,应该格式不对
 楼主| 发表于 2024-9-26 16:03:43 | 显示全部楼层
novleaf 发表于 2024-9-22 14:11
用vim打开/home/ic_eda/dh6_innovus/library/liberty/MEM1_256X32_slow.lib 看下,应该格式不对 ...
你好 我不会格式问题 日志里面是这样记录的 但看不懂
[09/21 13:25:50    151s] <CMD> init_design
[09/21 13:25:50    151s] #% Begin Load MMMC data ... (date=09/21 13:25:50, mem=557.7M)
[09/21 13:25:50    151s] child process exited abnormally
[09/21 15:44:43   2341s] **INFO (INTERRUPT): One more Ctrl-C to exit Innovus ...
[09/21 15:47:26   2385s] invalid command name "read_liberty"
GMT+8, 2025-12-14 13:17 , Processed in 0.012741 second(s), 4 queries , Gzip On, Redis On.
