楼主: 着着着火了
[原创] 一套自动跑drc、lvs和pex的csh脚本
发表于 2024-10-30 16:20:59 | 显示全部楼层
好东西
发表于 2024-10-30 16:30:07 | 显示全部楼层
*WARNING* envSetVal: Can't set the value of variable 'displayPRHighestResolution',
        in tool[.partition] 'graphic' - it has not been registered.
*WARNING* envSetVal: Can't set the value of variable 'displayResolution',
*WARNING* The directory: '********* does not exist
        but was defined in libFile '**********' for Lib 'basic'.
*WARNING* ddMapGetFileViewType: You are trying to run a CDB executable on an OA library file 'sch.oa'. The file is in library 'try_drc_lvs' in cell 'VccVoltageDet' in view 'schematic'. You must run an OA executable to use that library file.
*Error* dbClose: argument #1 should be a database object (type template = "d") - nil
*WARNING* dbOpenCellViewByType: Unable to open an OpenAccess design with CDBA application.
大佬 导出CDL出现这个问题怎么解决
 楼主| 发表于 2024-10-30 17:20:15 | 显示全部楼层
        in tool[.partiti ...
你是在IC51版本用这个脚本吗?IC51用不了,好像是要改指令,没测试过所以还不清楚怎么改
发表于 2024-10-30 17:23:46 | 显示全部楼层
感谢分享!
发表于 2024-11-5 20:36:20 | 显示全部楼层
感谢分享
发表于 2024-11-6 16:12:20 | 显示全部楼层
牛!!!!!!!!!!!!!!!!!!!!
发表于 2024-11-22 13:59:19 | 显示全部楼层
tkstks
发表于 2024-11-26 14:24:45 | 显示全部楼层
码住!感谢!
发表于 2024-11-28 09:57:36 | 显示全部楼层
mark...
发表于 2024-11-29 14:48:24 | 显示全部楼层
学习学习
GMT+8, 2025-10-1 23:11 , Processed in 0.020364 second(s), 5 queries , Gzip On, Redis On.
