查看: 3282|回复: 3
DIgSILENT PowerFactory 2024 SP4 with Complete Features
发表于 2024-8-31 07:00:07 | 显示全部楼层 |阅读模式
PowerFactory software is a product of the German company DigSILENT, which for more than 25 years has gathered a set of standards and trends for the modeling, analysis and simulation of power systems in the form of a set.   The established advantage of DIgSILENT PowerFactory software is its comprehensive integrated performance and its applicability in modeling production, transmission, distribution and industrial networks, as well as analyzing the mutual performance of these networks and restoring power to the network.   Electric networks, their planning processes and operational processes are becoming more and more complicated due to the spread of the market, the development of network interconnection and also the widespread production.  This increases the demand for tools that are in the form of computer programs and are reliable in terms of data quality, flexibility and manageability.   Along with the new versions of PowerFactory software, DigSILENT has been able to take a step forward in the direction of integrating operational capabilities and data management in a team work environment.   Creating and  organizing plans, scenarios, versions and durable arrangements are available for better organization DIgSILENT PowerFactory software is the most cost-effective solution in electrical engineering because its data organization, modeling ability, and general capabilities can replace a set of diverse software, thus reducing the cost of project implementation and the need for various trainings. at least   The PowerFactory software, which is designed as an All-in -One, provides an extremely optimal solution for electrical engineering work.   DigSilent Power Factory software is easy to use and provides essential analysis tools for all standard power systems, including new technological applications such as wind power and distributed generation and the organization of very large power systems.   In addition to the single-user system, this software can be easily integrated with other open standard systems such as GIS, DMS and EMS.
Some Features and features of DIgSILENT PowerFactory software:
- Import/Export operators of the program workspace (Workspace) and installation directory (Installation directory)
- Automatic login for single-user systems and user switching in multi-user systems
- The ability to archive to reduce the used space of the database and increase the functionality in systems with multi-user databases
- Importing integrated files
- Concept of geographic chart
- Graphic representation of protective devices and neutral connections
- DC direct current short circuit calculation
- The possibility of dynamic simulation
– Time-Overcurrent graph assistant and coordination
Algebraic sequential processing in virtual instruments
- Optimized manual reset for distribution networks
- New models for solar systems, impulse source, direct current machine and battery and RLC series filter
The significant developments in  PowerFactory 2024 include:
·        Extended functionality for the  Cable Analysis  module to meet revised industry standards as well as greater flexibility for cable layout specification
·        Developments in  Modelica  modeling for dynamic simulation, both in the model definition and the graphical representation
·        Enhancement to  Co-Simulation , allowing automatic region detection and definition for co-simulation
·        Support of curative redispatch in the  Unit Commitment and Dispatch Optimization  function
·        State Estimation for unbalanced networks , suitable for low voltage distribution grids
·        Incorporation of  LV Load Flow  into the  Hosting Capacity  and  Connection Request  functions
·        Many new and enhanced  Power Equipment Models , to support extended calculation features and offer greater flexibility in modeling
·        Extensions to the Drawing and Diagram Layout Tools  to allow easy creation and representation of complex elements such as towers, cable systems or controllers, as well as network groupings
·        Introduction of  user-defined Hotkeys  and a customisable  Quick Access  menu
For more information about DIgSILENT PowerFactory 2024 SP4, please contact   fast.forever24@gmail.com
发表于 2024-8-31 07:23:01 | 显示全部楼层
thanks
发表于 2024-11-2 08:13:12 | 显示全部楼层
目前非常需要
发表于 2025-5-8 15:14:53 | 显示全部楼层
GMT+8, 2025-12-22 01:14 , Processed in 0.019730 second(s), 4 queries , Gzip On, Redis On.
