楼主: smc1017
Synopsys License Error
发表于 2024-10-2 10:07:29 | 显示全部楼层
Any one have have Sentaurus 2023 or 2024 installation package.?
发表于 2024-10-2 10:08:21 | 显示全部楼层
Do you have Sentaurus 2023 or 2024 installation package
发表于 2024-10-12 17:19:57 | 显示全部楼层
请问是否可以share 一下这个license 生成器
发表于 2024-10-14 03:40:01 | 显示全部楼层
joshua2784920 发表于 2024-7-30 08:00
In my running test of "Fusion Compiler" with your license file, tere is no issue.
This mean th ...
Could you please provide me your license file to me reference?
I want to add 2 keys ICCompilerII-AG3  and ICCompilerII-NX-AG3, Please help me to add them to your license file.
Thanks!!
发表于 2024-10-18 17:42:04 | 显示全部楼层
smc1017 发表于 2024-7-29 19:32
here is the file.
感谢分享
发表于 2024-10-18 17:49:28 | 显示全部楼层
感谢楼上各位分享。
发表于 2024-12-23 14:55:58 | 显示全部楼层
joshua2784920 发表于 2024-8-2 21:27
TT.7z file include below files.
我按你的方法在 icc2/W-2024.09
                        syn/W-2024.09
        % pubkey_verify -y
        % synopsys_checksum -y
启动提示,请问这个license问题,还是其它问题呢。license启动如下
14:48:45 (snpslmd) (@snpslmd-SLOG@) ===============================================
14:48:45 (snpslmd) (@snpslmd-SLOG@) === Vendor Daemon ===
14:48:45 (snpslmd) (@snpslmd-SLOG@) Vendor daemon: snpslmd
14:48:45 (snpslmd) (@snpslmd-SLOG@) Start-Date: Mon Dec 23 2024 14:48:45 CST
14:48:45 (snpslmd) (@snpslmd-SLOG@) PID: 12909
14:48:45 (snpslmd) (@snpslmd-SLOG@) VD Version: v11.19.6.0 build 293152 x64_linux ( build 293152 (ipv6))
14:48:45 (snpslmd) (@snpslmd-SLOG@) === Startup/Restart Info ===
14:48:45 (snpslmd) (@snpslmd-SLOG@) Options file used: None
14:48:45 (snpslmd) (@snpslmd-SLOG@) Is vendor daemon a CVD: Yes
14:48:45 (snpslmd) (@snpslmd-SLOG@) Is FlexNet Licensing Service installed and compatible: No
14:48:45 (snpslmd) (@snpslmd-SLOG@) FlexNet Licensing Service Version: -NA-
14:48:45 (snpslmd) (@snpslmd-SLOG@) Is TS accessed: No
14:48:45 (snpslmd) (@snpslmd-SLOG@) TS access time: -NA-
14:48:45 (snpslmd) (@snpslmd-SLOG@) Number of VD restarts since LS startup: 0
14:48:45 (snpslmd) (@snpslmd-SLOG@) === Network Info ===
14:48:45 (snpslmd) (@snpslmd-SLOG@) Listening port: 45229
14:48:45 (snpslmd) (@snpslmd-SLOG@) Daemon select timeout (in seconds): 1
14:48:45 (snpslmd) (@snpslmd-SLOG@) === Host Info ===
14:48:45 (snpslmd) (@snpslmd-SLOG@) Host used in license file: syn
14:48:45 (snpslmd) (@snpslmd-SLOG@) HostID node-locked in license file: fefcfebb16eb
14:48:45 (snpslmd) (@snpslmd-SLOG@) HostID of the License Server: fefcfebb16eb
14:48:45 (snpslmd) (@snpslmd-SLOG@) Running on Hypervisor: Unknown Hypervisor
14:48:45 (snpslmd) Ecomms: Encrypted Communication disabled
14:48:45 (snpslmd) TCP_NODELAY NOT enabled
14:48:45 (snpslmd) Listener Thread: running
工具启动如下
[tcad@SYN ~]$ dc_shell
/usr/synopsys/syn/W-2024.09-SP1/bin/dc_shell: /usr/synopsys/syn/W-2024.09-SP1/bin/snps_platform: /bin[img]file:///C:\Users\SSZ23038\AppData\Roaming\Tencent\QQTempSys\ZAR6G6Y10HXK[JL2VDH3PA0.gif[/img]h: bad interpreter: No such file or directory
Info: [VCS_SAVE_RESTORE_INFO] ASLR (Address Space Layout Randomization) is detected on the machine. To enable $save functionality, ASLR will be switched off and simv re-executed.
Please use '-no_save' simv switch to avoid this.
Fatal: Design Compiler is not enabled. (DCSH-1)
[tcad@syn ~]$ icc2_shell
[SCL] Error:  One possible reason for this error is that FLEXlm version of the application is higher than the license daemon version. If this is the case, please upgrade the license daemon to latest version (SCL-602)
Unable to get shell start-up license keys. Cannot invoke shell. Following license(s) must exist : {ICCompilerII or ICCompilerII-NX}.
Maximum memory usage for this session: 105.59 MB
Maximum memory usage for this session including child processes: 105.59 MB
CPU usage for this session:      7 seconds (  0.00 hours)
Elapsed time for this session:      7 seconds (  0.00 hours)
Thank you for using IC Compiler II.
发表于 2024-12-23 23:04:46 | 显示全部楼层
Ok.. any solution!!
发表于 2024-12-27 19:44:44 | 显示全部楼层
Thankyou
发表于 2025-1-24 11:19:41 | 显示全部楼层
感谢
GMT+8, 2025-11-3 19:20 , Processed in 0.025102 second(s), 3 queries , Gzip On, Redis On.
