查看: 2711|回复: 10
DVE-addon 安装包怎么安装呢?求dve_vT-2022.06-SP2
发表于 2024-6-27 10:54:37 | 显示全部楼层 |阅读模式
VCS找不到DVE,发现过了2020后,新的版本dve需要单独装,但是安装路径有问题,不会自动找到vcs目录,如图,vcs_vT-2022.06-SP2安装dve_vT-2022.06
需要dve_vT-2022.06-SP2做个测试,验证是否会自动匹配vcs安装目录
 楼主| 发表于 2024-6-27 14:35:16 | 显示全部楼层
DVE-addon 安装包怎么安装呢?换资源,vcs换dve啊!!求dve_vT-2022.06-SP2
没人来,放资源出来啦,有DVE的给个啊
链接: https://pan.baidu.com/s/1TRPisHSP0W22yUsdWexw4Q 提取码: 4g4a
发表于 2024-6-27 14:44:12 | 显示全部楼层
dve and  vcs  must use same version ....
and you can copy dve install file to vcs folders..
then ./installer -gui
you can find vcs and dve .. then  install them
**** same version must ***
 楼主| 发表于 2024-6-27 15:37:02 | 显示全部楼层
I see .
 楼主| 发表于 2024-6-27 15:38:12 | 显示全部楼层
I got the same version package,and I'm trying to check just now
发表于 2024-6-27 15:46:05 | 显示全部楼层
感谢分享
 楼主| 发表于 2024-6-27 16:20:29 | 显示全部楼层
I'm back~
In step three, the person must be changing the directory "target dir" vcshome/
Then we can run crack package~
发表于 2024-6-27 21:27:47 | 显示全部楼层
thanks
发表于 2024-7-17 17:24:19 | 显示全部楼层
Please share DVE version vV2023 SP1 if someone has it
be very appreciated
发表于 2024-8-22 22:52:06 | 显示全部楼层
给dve和vcs放一个目录,一起装
GMT+8, 2025-12-8 14:03 , Processed in 0.029897 second(s), 4 queries , Gzip On, Redis On.
