查看: 2411|回复: 11
calibre LVS is not working
发表于 2024-6-25 20:02:04 | 显示全部楼层 |阅读模式
lvs
lvs
source path:export from source : viewer not connected
any one help me how to resolve this, im facing this issue only in 2023 & 2024 calibre version.
发表于 2024-6-25 20:08:42 | 显示全部楼层
下面两栏呢
发表于 2024-6-25 21:40:00 | 显示全部楼层
这里面有给connect点一下就行
 楼主| 发表于 2024-6-26 13:09:30 | 显示全部楼层
In-lucky 发表于 2024-6-25 21:40
这里面有给connect点一下就行
what i need to change in run control ?
发表于 2024-6-26 15:55:09 | 显示全部楼层
thanks
发表于 2024-6-26 16:46:50 | 显示全部楼层
还是用老界面把
 楼主| 发表于 2024-8-19 01:29:30 | 显示全部楼层
issue resolved
发表于 2024-12-20 09:56:35 | 显示全部楼层
youngjevon 发表于 2024-6-26 16:46
还是用老界面把
请问,怎么换老界面
发表于 2024-12-20 10:14:17 | 显示全部楼层
wanglixin0425 发表于 2024-12-20 09:56
请问,怎么换老界面
bash
export CALIBRE_ENABLE_CLASSIC_CI_LVS=1
export CALIBRE_ENABLE_CLASSIC_CI_DRC=1
export CALIBRE_ENABLE_CLASSIC_CI_PERC=1
export CALIBRE_ENABLE_CLASSIC_CI_PEX=1
csh
setenv CALIBRE_ENABLE_CLASSIC_CI_LVS 1
setenv CALIBRE_ENABLE_CLASSIC_CI_DRC 1
setenv CALIBRE_ENABLE_CLASSIC_CI_PERC 1
setenv CALIBRE_ENABLE_CLASSIC_CI_PEX 1
回复 支持 2 反对 0
发表于 2024-12-20 10:56:30 | 显示全部楼层
非常感谢,非常感谢。
我还有个问题:启动ic618时报错,这个怎么解决呢
Qt Warning: QXcbConnection: XCB error: 1 (BadRequest), sequence: 170, resource id: 87, major code: 150 (Unknown), minor code: 31
Qt Warning: failed to get the primary output of the screen
GMT+8, 2025-12-28 09:51 , Processed in 0.021250 second(s), 4 queries , Gzip On, Redis On.
