楼主: PXIAOH
ubuntu24.02运行dc:../libpthread.so.0: version `GLIBC_PRIVATE' not found
发表于 2024-7-10 22:01:41 | 显示全部楼层
刘兴国 发表于 2024-7-9 21:32
楼主分享的zip里边下边这些库是没有的,但是运行dc似乎需要。楼主能找到分享一下吗?
好啦,哈哈。我又装了一个ubuntu20.04 的WSL虚拟机,把里边glibc2.3的动态链接库拷到了装synopsys的主机里,dc终于能运行了。Yeah!
点评
In which folder files should be copied? For me, it is not working on Ubuntu 22.04  发表于 2024-11-16 23:28
发表于 2024-7-10 22:07:25 | 显示全部楼层
刘兴国 发表于 2024-7-10 22:01
好啦,哈哈。我又装了一个ubuntu20.04 的WSL虚拟机,把里边glibc2.3的动态链接库拷到了装synopsys的主机 ...
附上copy的包。 glibc-2.31缺失的包.zip (233.17 KB , 下载次数: 106 )
发表于 2024-8-19 15:04:55 | 显示全部楼层
PXIAOH 发表于 2024-6-12 10:14
我笔记本配置是目前笔记本的主流配置,centos不管怎么装,总是时不时会卡顿一下。特别是鼠标,放到窗口边 ...
应该是centos的驱动没装好,比如显卡
发表于 2024-8-19 16:39:06 | 显示全部楼层
感谢分享
发表于 2024-8-21 17:22:18 | 显示全部楼层
想问下,
  1. home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/libpthread.so.0: undefined reference to `__libc_dlopen_mode@GLIBC_PRIVATE'
  2. /home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/libpthread.so.0: undefined reference to `__libc_current_sigrtmin_private@GLIBC_PRIVATE'
  3. /home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/libpthread.so.0: undefined reference to `__libc_dlclose@GLIBC_PRIVATE'
  4. /home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/libdl.so.2: undefined reference to `_dl_sym@GLIBC_PRIVATE'
  5. /home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/libpthread.so.0: undefined reference to `__libc_longjmp@GLIBC_PRIVATE'
  6. /home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/librt.so.1: undefined reference to `__clock_nanosleep@GLIBC_PRIVATE'
  7. /home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/libpthread.so.0: undefined reference to `__libc_dl_error_tsd@GLIBC_PRIVATE'
  8. /home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/libpthread.so.0: undefined reference to `__libc_allocate_rtsig_private@GLIBC_PRIVATE'
  9. /home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/librt.so.1: undefined reference to `__clock_getres@GLIBC_PRIVATE'
  10. /home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/libpthread.so.0: undefined reference to `__libc_thread_freeres@GLIBC_PRIVATE'
  11. /home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/libpthread.so.0: undefined reference to `__libc_dlsym@GLIBC_PRIVATE'
  12. /home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/librt.so.1: undefined reference to `__clock_getcpuclockid@GLIBC_PRIVATE'
  13. /home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/libpthread.so.0: undefined reference to `__libc_current_sigrtmax_private@GLIBC_PRIVATE'
  14. /home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/libdl.so.2: undefined reference to `_dl_addr@GLIBC_PRIVATE'
  15. /home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/libdl.so.2: undefined reference to `_dl_vsym@GLIBC_PRIVATE'
  16. /home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/libpthread.so.0: undefined reference to `__libc_pthread_init@GLIBC_PRIVATE'
  17. /home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/librt.so.1: undefined reference to `__clock_settime@GLIBC_PRIVATE'
  18. /home/cmj/chipyard/.conda-env/bin/ld: /home/cmj/chipyard/.conda-env/bin/../x86_64-conda-linux-gnu/sysroot/lib64/libpthread.so.0: undefined reference to `_dl_make_stack_executable@GLIBC_PRIVATE'
    复制代码
这一串是怎么回事?我是在Ubuntu22.04上装的VCS, glibc从2.35转到了2.31.
 楼主| 发表于 2024-8-21 18:46:22 | 显示全部楼层
我现在已经用回20.04版本的ubuntu了,因为spectre再24.04里跑仿真总是提示无法编译va(其实就是不兼容),我解决不掉
 楼主| 发表于 2024-8-22 14:33:41 | 显示全部楼层
Happy_Fish 发表于 2024-8-21 17:22
想问下,
转glibc版本这个,一定不要替换系统自带的版本,也不要设置软连接到lib64/之类的系统库文件夹,也不需要添加至环境变量,这个兼容操作只针对dc软件;VCS是不需要进行这个操作的;此外,我用的VCS也是2018版本,暂时没有尝试其他版本
发表于 2024-8-31 10:55:17 | 显示全部楼层
我也是 在centos虚拟机中安装的 vcs。编译慢得要死。ubuntun下编译只要几秒。centos下编译要 几十秒。
发表于 2024-10-4 16:59:58 | 显示全部楼层
thanks
发表于 2024-10-9 11:53:33 | 显示全部楼层
gcc4 有15年了吧?老版本vcs 非要用 老glibc里的一个bug
GMT+8, 2025-12-14 15:55 , Processed in 0.026362 second(s), 10 queries , Gzip On, Redis On.
