查看: 3955|回复: 8
[求助] virtuoso后仿netlist error报错
发表于 2024-6-3 01:44:59 | 显示全部楼层 |阅读模式
微信图片_20240603014459.png drc和lvs全部跑通,提取网表0error 0warning,但是运行不了仿真,报错如下,求助。。
ERROR (0SSHNL-913): Netlisting failed because terminal 'mustConnect 1_G' of instance 'l3' in cellview 'test/bandgapi/layoutdoes not exist in switch master 'tsmc18/pmos3v/spectre', To continue netlisting, either setthe 'simCheckTermlismatchAction'to ignore',or set the'sinCheckTermMismatchAction'to 'warning'and 'nlAction' to 'ignore' for themissing terminal.
ERROR (0SSHNL-913): Netlisting failed because terminal 'mustconect 2_G’ of instance 'l3’ in cellview 'test/bandgapi/layoutdoes not exist in switch master 'tsmc18/pmos3v/spectre', To continue netlisting, either setthe 'simCheckTermlismatchAction'toignore',or set the'sinCheckTermMismatchAction'to 'warning’ and 'nlAction' to 'ignore' for themissing termina1
ERROR (0SSHNL-913): Netlisting failed because terminal 'mustonect 3 G’of instance '3’ in cellview 'test/bandgapi/layout'does not exist in switch master 'tsmc18/pmos3v/spectre', To continue netlisting, either setthe 'simCheckTermlismatchAction'to'ignore',or set the'simCheckTermMismatchAction'to 'warning'and 'nlAction' to 'ignore' for themissing terminal.
ERROR (0SSHNL-913): Netlisting failed because terminal 'mustConnect 0 D' of instance 'l3' in cellview "test/bandgapi/layoutdoes not exist in switch master 'tsnc8/pmos3v/spectre', To continue netlisting, either setthe 'simCheckTermlismatchAction'toignore',or set the'simCheckTermMismatchAction'to 'warning' and 'nlAction' to 'ignore' for themissing terminal.
ERROR (OSSHNL-913): Netlisting failed because terminal 'mustConnect_1_D' of instance '3’ in cellview "test/bandgap1/layout'does not exist in switch master 'tsmc18/pmos3v/spectre', To continue netlisting, either setthe 'simCheckTermlismatchAction'to'ignore',or set the'sinCheckTermMismatchAction'to 'warning’and 'nlAction' to 'ignore' for themissing terminal.
ERROR (0SSHNL-514): letlist generation failed because of the errors reported above. The netlist might not have been generated at all
or the generated netlist could be corrupt, Fix the reported errors and regenerate the netlist.
.unsuccessfu1.
发表于 2024-6-3 09:24:05 | 显示全部楼层
你是不是仿真没有切成calibre啊
发表于 2024-6-3 17:16:04 | 显示全部楼层
是不是没设置好
发表于 2024-6-3 17:22:51 | 显示全部楼层
port大写
 楼主| 发表于 2024-6-3 20:43:21 | 显示全部楼层
不是大写的问题,最后复制calibre到顶层就好了
发表于 2024-7-5 14:30:38 | 显示全部楼层
请问楼主,这是什么意思,版图新手
发表于 2024-10-18 11:31:34 | 显示全部楼层
楼主同样的问题,如何将calibre复制到顶层呢?
 楼主| 发表于 2024-10-22 12:00:15 | 显示全部楼层
当时因为作业快截止了都没好好思考就发帖问了好多问题,现在我也记不清了,好像按照网上教程从头来一遍就能跑了,我记得是在仿真环境里复制calibre进去
发表于 5 天前 | 显示全部楼层
最终解决了吗
我也有这个问题
GMT+8, 2025-10-21 12:09 , Processed in 0.023939 second(s), 4 queries , Gzip On, Redis On.
