楼主: MISU
[求助] LVS仿真电容电阻始终过不了
 楼主| 发表于 2024-5-31 14:10:17 | 显示全部楼层
飞翔的鸟 发表于 2024-5-31 13:54
你目前属于LVS从版图里面提取不到器件,你可以测试一下,新建一个layout,将版图这两个器件单独放入里面跑L ...
可以帮忙看看规则文件应该怎么设置吗
发表于 2024-5-31 14:11:54 | 显示全部楼层
把加的那个删掉
 楼主| 发表于 2024-5-31 14:16:37 | 显示全部楼层
Cheney聪 发表于 2024-5-31 14:11
把加的那个删掉
#DEFINE MIM_PROPERTY C
#DEFINE RES_PROPERTY R
顶头的这两句需要删吗,另外其他的哪里需要修改吗
发表于 2024-5-31 14:17:18 | 显示全部楼层
你删掉跑一下,看结果
 楼主| 发表于 2024-5-31 14:20:49 | 显示全部楼层
Cheney聪 发表于 2024-5-31 14:17
你删掉跑一下,看结果
还是一样的电容电阻** missing instance **       以及中间的那根线** missing net **
发表于 2024-5-31 14:28:57 | 显示全部楼层
PDK按照要求正常安装吗?是否选择了正确的电阻?
发表于 2024-5-31 14:29:54 | 显示全部楼层
赞同楼上,report 贴出看下
 楼主| 发表于 2024-5-31 14:33:31 | 显示全部楼层
test2022 发表于 2024-5-31 14:29
赞同楼上,report 贴出看下
你好  这是report文件
                  ##         C A L I B R E    S Y S T E M         ##
                  ##             L V S   R E P O R T              ##
REPORT FILE NAME:         OP_2stage_mul.lvs.report
LAYOUT NAME:              /home/work/learn_lib/LVS/OP_2stage_mul.sp ('OP_2stage_mul')
SOURCE NAME:              /home/work/learn_lib/LVS/OP_2stage_mul.src.net ('OP_2stage_mul')
RULE FILE:                /home/work/learn_lib/LVS/_SmicSP12R_cal018_epm_sali_p2mtx_18335155.lvs_
CREATION TIME:            Fri May 31 14:19:43 2024
CURRENT DIRECTORY:        /home/work/learn_lib/LVS
USER NAME:                work
CALIBRE VERSION:          v2015.2_36.27    Wed Jul 1 10:06:07 PDT 2015
                               OVERALL COMPARISON RESULTS
                    #           #     INCORRECT     #
  Error:    Different numbers of nets.
  Error:    Different numbers of instances.
  Warning:  Unbalanced smashed mosfets were matched.
                                      CELL  SUMMARY
  Result         Layout                        Source
  INCORRECT      OP_2stage_mul                 OP_2stage_mul
                                      LVS PARAMETERS
o LVS Setup:
   // LVS COMPONENT TYPE PROPERTY
   // LVS COMPONENT SUBTYPE PROPERTY
   // LVS PIN NAME PROPERTY
   LVS POWER NAME                         "VDD"
   LVS GROUND NAME                        "GND"
   LVS CELL SUPPLY                        NO
   LVS RECOGNIZE GATES                    ALL
   LVS IGNORE PORTS                       NO
   LVS CHECK PORT NAMES                   YES
   LVS IGNORE TRIVIAL NAMED PORTS         NO
   LVS BUILTIN DEVICE PIN SWAP            YES
   LVS ALL CAPACITOR PINS SWAPPABLE       YES
   LVS DISCARD PINS BY DEVICE             NO
   LVS SOFT SUBSTRATE PINS                NO
   LVS INJECT LOGIC                       YES
   LVS EXPAND UNBALANCED CELLS            YES
   LVS FLATTEN INSIDE CELL                NO
   LVS EXPAND SEED PROMOTIONS             NO
   LVS PRESERVE PARAMETERIZED CELLS       NO
   LVS GLOBALS ARE PORTS                  YES
   LVS REVERSE WL                         NO
   LVS SPICE PREFER PINS                  YES
   LVS SPICE SLASH IS SPACE               YES
   LVS SPICE ALLOW FLOATING PINS          YES
   // LVS SPICE ALLOW INLINE PARAMETERS
   LVS SPICE ALLOW UNQUOTED STRINGS       NO
   LVS SPICE CONDITIONAL LDD              NO
   LVS SPICE CULL PRIMITIVE SUBCIRCUITS   NO
   LVS SPICE IMPLIED MOS AREA             NO
   // LVS SPICE MULTIPLIER NAME
   LVS SPICE OVERRIDE GLOBALS             NO
   LVS SPICE REDEFINE PARAM               NO
   LVS SPICE REPLICATE DEVICES            NO
   LVS SPICE SCALE X PARAMETERS           NO
   LVS SPICE STRICT WL                    NO
   // LVS SPICE OPTION
   LVS STRICT SUBTYPES                    NO
   LVS EXACT SUBTYPES                     NO
   LAYOUT CASE                            NO
   SOURCE CASE                            NO
   LVS COMPARE CASE                       NO
   LVS DOWNCASE DEVICE                    NO
   LVS REPORT MAXIMUM                     50
   LVS PROPERTY RESOLUTION MAXIMUM        65536
   // LVS SIGNATURE MAXIMUM
   // LVS FILTER UNUSED OPTION
   // LVS REPORT OPTION
   LVS REPORT UNITS                       YES
   // LVS NON USER NAME PORT
   // LVS NON USER NAME NET
   // LVS NON USER NAME INSTANCE
   // LVS IGNORE DEVICE PIN
   // Reduction
   LVS REDUCE SERIES MOS                  NO
   LVS REDUCE PARALLEL MOS                YES
   LVS REDUCE SEMI SERIES MOS             NO
   LVS REDUCE SPLIT GATES                 YES
   LVS REDUCE PARALLEL BIPOLAR            YES
   LVS REDUCE SERIES CAPACITORS           YES
   LVS REDUCE PARALLEL CAPACITORS         YES
   LVS REDUCE SERIES RESISTORS            YES
   LVS REDUCE PARALLEL RESISTORS          YES
   LVS REDUCE PARALLEL DIODES             YES
   LVS REDUCTION PRIORITY                 PARALLEL
   LVS SHORT EQUIVALENT NODES             NO
   // Trace Property
   TRACE PROPERTY  mn(n18e2r)  l l 5
   TRACE PROPERTY  mn(n18e2r)  w w 5
   TRACE PROPERTY  mn(nz18e2r)  l l 5
   TRACE PROPERTY  mn(nz18e2r)  w w 5
   TRACE PROPERTY  mp(p18e2r)  l l 5
   TRACE PROPERTY  mp(p18e2r)  w w 5
   TRACE PROPERTY  mn(n33e2r)  l l 5
   TRACE PROPERTY  mn(n33e2r)  w w 5
   TRACE PROPERTY  mp(p33e2r)  l l 5
   TRACE PROPERTY  mp(p33e2r)  w w 5
   TRACE PROPERTY  mn(n50e2r)  l l 5
   TRACE PROPERTY  mn(n50e2r)  w w 5
   TRACE PROPERTY  mp(p50e2r)  l l 5
   TRACE PROPERTY  mp(p50e2r)  w w 5
   TRACE PROPERTY  mn(nz50e2r)  l l 5
   TRACE PROPERTY  mn(nz50e2r)  w w 5
   TRACE PROPERTY  mn(n155e2r)  l l 5
   TRACE PROPERTY  mn(n155e2r)  w w 5
   TRACE PROPERTY  mn(nz155e2r)  l l 5
   TRACE PROPERTY  mn(nz155e2r)  w w 5
   TRACE PROPERTY  mp(p155e2r)  l l 5
   TRACE PROPERTY  mp(p155e2r)  w w 5
   TRACE PROPERTY  mn(n18d)  l l 5
   TRACE PROPERTY  mn(n18d)  w w 5
   TRACE PROPERTY  mn(n18h)  l l 5
   TRACE PROPERTY  mn(n18h)  w w 5
   TRACE PROPERTY  mn(nsg)  l l 5
   TRACE PROPERTY  mn(nsg)  w w 5
   TRACE PROPERTY  mn(ncg)  l l 5
   TRACE PROPERTY  mn(ncg)  w w 5
   TRACE PROPERTY  pvar18e2r_ckt  wr wr 5
   TRACE PROPERTY  pvar18e2r_ckt  lr lr 5
   TRACE PROPERTY  pvar18e2r_ckt  nf nf 0
   TRACE PROPERTY  q(pnp18a4e2r)  a a 5
   TRACE PROPERTY  q(pnp18a25e2r)  a a 5
   TRACE PROPERTY  q(pnp18a100e2r)  a a 5
   TRACE PROPERTY  q(pnp33a4e2r)  a a 5
   TRACE PROPERTY  q(pnp33a25e2r)  a a 5
   TRACE PROPERTY  q(pnp33a100e2r)  a a 5
   TRACE PROPERTY  d(pdio18e2r)  a a 5
   TRACE PROPERTY  d(pdio33e2r)  a a 5
   TRACE PROPERTY  d(pdio50e2r)  a a 5
   TRACE PROPERTY  d(pdio155e2r)  a a 5
   TRACE PROPERTY  d(ndio18e2r)  a a 5
   TRACE PROPERTY  d(ndio33e2r)  a a 5
   TRACE PROPERTY  d(ndio50e2r)  a a 5
   TRACE PROPERTY  d(ndio155e2r)  a a 5
   TRACE PROPERTY  d(nzdio50e2r)  a a 5
   TRACE PROPERTY  d(nzdio155e2r)  a a 5
   TRACE PROPERTY  d(nwdioe2r)  a a 5
   TRACE PROPERTY  d(dnwdioe2r)  a a 5
   TRACE PROPERTY  c(cgttow)  c c 5
   TRACE PROPERTY  pipe2r_ckt  c c 5
   TRACE PROPERTY  r(rpgt)  r r 5
   TRACE PROPERTY  r(rngtsab)  r r 5
   TRACE PROPERTY  r(rpgtsab)  r r 5
   TRACE PROPERTY  r(rncgsab)  r r 5
   TRACE PROPERTY  r(rm1)  r r 5
   TRACE PROPERTY  r(rm2)  r r 5
   TRACE PROPERTY  r(rm3)  r r 5
   TRACE PROPERTY  r(rm4)  r r 5
   TRACE PROPERTY  r(rm5)  r r 5
   TRACE PROPERTY  r(rm6)  r r 5
                   CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Different numbers of nets (see below).
  Error:    Different numbers of instances (see below).
LAYOUT CELL NAME:         OP_2stage_mul
SOURCE CELL NAME:         OP_2stage_mul
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:              6         6
Nets:              12        13    *
Instances:         26         7    *    MN (4 pins)
                    49         7    *    MP (4 pins)
                     0         1    *    C (2 pins)
                     0         1    *    R (2 pins)
Total Inst:        75        16
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:              6         6
Nets:              11        12    *
Instances:          5         5         MN (4 pins)
                     6         6         MP (4 pins)
                     0         1    *    C (2 pins)
                     0         1    *    R (2 pins)
                     1         1         _smn2v (4 pins)
Total Inst:        12        14
       * = Number of objects in layout different from number in source.
                                 INCORRECT OBJECTS
LEGEND:
  ne  = Naming Error (same layout name found in source
        circuit, but object was matched otherwise).
                                   INCORRECT NETS
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    ** missing net **                                         net26
                                 INCORRECT INSTANCES
  2    ** missing instance **                                    RR0  R(RNDIF)
  3    ** missing instance **                                    CC2  C(MIME2R)
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:               6          6            0            0
   Nets:               11         11            0            1
   Instances:           5          5            0            0    MN(N33E2R)
                        6          6            0            0    MP(P33E2R)
                        0          0            0            1    C(MIME2R)
                        0          0            0            1    R(RNDIF)
                        1          1            0            0    _smn2v
   Total Inst:         12         12            0            2
o Statistics:
   68 layout mos transistors were reduced to 6.
     62 mos transistors were deleted by parallel reduction.
   2 source mos transistors were reduced to 1.
     1 mos transistor was deleted by parallel reduction.
o Initial Correspondence Points:
   Ports:        VDD GND VIN- VIN+ OUT BIS
o Matched Mosfets Which Have Been Unequally Reduced:
       M1(21.585,26.480)                                         MM14
       M12(40.225,40.395)                                        MM15
       M11(40.225,26.480)                                        ** missing smashed mosfet **
       M2(21.585,40.395)                                         ** missing smashed mosfet **
                                         SUMMARY
Total CPU Time:      0 sec
Total Elapsed Time:  0 sec
 楼主| 发表于 2024-5-31 14:34:19 | 显示全部楼层
是正常安装的,电阻选的是rndif
发表于 2024-5-31 14:36:32 | 显示全部楼层
电阻、电容都没识别出来,看下安装PDK选项是不是选对了
GMT+8, 2025-10-1 09:23 , Processed in 0.015621 second(s), 3 queries , Gzip On, Redis On.
