查看: 1554|回复: 2
[求助] tessent mbist flow报错求问
发表于 2024-5-30 15:25:54 | 显示全部楼层 |阅读模式
悬赏20资产未解决
在执行set_dft_specification_requirements -memory_test on时出现warning:
warning: No modules with attribute tcd memory name or tcd memory cluster name
and no child blocks with memories found. Verify your 'set design source -format tcd memory( cluster)'!
settings if you are supposed to have some or use -memory bist off if you are not
.memlib文件是仿照手册自己写的
发表于 2024-6-4 11:24:35 | 显示全部楼层
检查一下你写的tcd,大概率是写tcd 缺失关键的memory 标识信息
发表于 2024-6-12 17:56:35 | 显示全部楼层
这个肯定的是tcd的问题,你的tcd里面的ram和design好像对不上,我感觉时这个问题?不知道对不
GMT+8, 2025-9-11 11:42 , Processed in 0.026855 second(s), 3 queries , Gzip On, Redis On.
