查看: 1336|回复: 1
[讨论] 用片上电感 Inductor-Based Integrated Buck
发表于 2024-5-18 07:53:21 | 显示全部楼层 |阅读模式
Spiral Inductor-Based Integrated Buck
用片上电感 好处为和?  片上电感 能到多大电流 ?
EM8103  这电感  是 独立电感 还是说CMOS metal 电感
14.9: A Monolithic 10.5W/mm2 600MHz Top-Metal and C4 Planar Spiral Inductor-Based Integrated Buck Voltage Regulator on 16nm-Class CMOS
Integrated spiral inductor with substrate silicon in a buck converter
Integrated square shape inductor with magnetic core in a buck converter DC-DC
Integrated square shape inductor with magnetic core in a buck.pdf (476.25 KB , 下载次数: 12 )
3D Stacked Buck Converter with 15μm Thick Spiral
3D Stacked Buck Converter with 15μm Thick Spiral.pdf (265.14 KB , 下载次数: 11 )
Design and simulation of integrated spiral inductor a boost
converter for photovoltaic application
Design and simulation of integrated spiral inductor a boost.pdf (684.25 KB , 下载次数: 12 )
who can upload theis paper
A 100 MHz DC-DC Converter Using Integrated Inductor
thank you .
some use package integrated
PMICs with Integrated Passive Components
Another Integrated Voltage Regulator Example from Empower Semiconductor
https://www.techinsights.com/zh-tw/node/49776
发表于 2024-5-18 10:40:24 | 显示全部楼层
Good.
GMT+8, 2025-9-29 05:31 , Processed in 0.011917 second(s), 4 queries , Gzip On, Redis On.
