查看: 1091|回复: 1
[求助] PEX参数提取后,使用config进行HSPICE后仿真,但是发生错误
发表于 2024-4-24 15:05:39 | 显示全部楼层 |阅读模式
ADEL中加了HSPICE模型文件,
但是hspice.out显示hspice: Command not found.
CIW显示
End netlisting Apr 24 02:51:41 2024
        The netlist is up to date.
        Time taken to compare the design with netlist:   0.0s
      ...successful.
compose simulator input file...
      ...successful.
start simulator if needed...
      ...successful.
*Warning* The version of the Hspice simulator that you are using may not
          support the generation of PSF output on Linux. If you are having
          trouble viewing simulation results, please contact Hspice customer
          support to identify the version that supports this capability.
simulate...
INFO (ADE-3069): Errors encountered during simulation. For more information, see the log files
        accessible from the Simulation -> Output Log menu.
求大佬帮个忙
 楼主| 发表于 2024-4-24 21:55:40 | 显示全部楼层
自己顶一下
GMT+8, 2025-9-21 17:33 , Processed in 0.022548 second(s), 3 queries , Gzip On, Redis On.
