查看: 1341|回复: 3
有谁知道怎么强制释放 cliosoft的license吗
发表于 2024-4-9 17:29:51 | 显示全部楼层 |阅读模式
使用命令 lmremove 释放license时得到以下错误信息:
lmremove: Cannot remove a linger license. (-100,398)
有谁知道怎么强制释放 吗?
发表于 2024-4-9 20:32:24 | 显示全部楼层
you cannot remove a borrowed license, you have to reduce the default linger timeout or just restart license service to reset to default  timeout and then wait for it been released.
 楼主| 发表于 2024-4-10 11:45:30 | 显示全部楼层
taiakun 发表于 2024-4-9 20:32
you cannot remove a borrowed license, you have to reduce the default linger timeout or just restart  ...
thanks, taiakun。
I restart the license ,but still cannot release license.
do you know how to reduce the default linger time?
发表于 2024-4-11 09:44:12 | 显示全部楼层
check option file for linger setting, or get another copy that without linger enabled/reduced from vendor, usually it will be released when timeout of linger reached
GMT+8, 2025-12-4 09:52 , Processed in 0.013731 second(s), 4 queries , Gzip On, Redis On.
