查看: 1866|回复: 2
【求助】ICADVM 201 启动时 license 报错 以及 license破解
发表于 2024-4-9 09:19:01 | 显示全部楼层 |阅读模式
我自己在试着装 cadence的icadvm 201 结果发现他的license报错了,用的ic618的license。我装了下618发现是可以使用的,是不是这个license是不通用的?有没有相关的破解教程呢?
COPYRIGHT (C) 1992-2020  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
          (C) 1992-2020  UNIX SYSTEMS Laboratories INC.,
                         Reproduced with permission.
This Cadence Design Systems program and online documentation are
proprietary/confidential information and may be disclosed/used only
as authorized in a license agreement controlling such use and disclosure.
          RESTRICTED RIGHTS NOTICE (SHORT FORM)
Use/reproduction/disclosure is subject to restriction
set forth at FAR 1252.227-19 or its equivalent.
ERROR (ELI-00111) Failed to check out license '111'.
ERROR (ELI-00133) Failed to launch the application because the required license is not available. Ensure that the environment variables are set correctly and that the license server is up and has the required licenses available.
发表于 2025-7-24 15:01:15 | 显示全部楼层
遇到了同样的问题,请问您的问题解决了吗
 楼主| 发表于 2025-8-27 12:53:49 | 显示全部楼层
chaochao3 发表于 2025-7-24 15:01
遇到了同样的问题,请问您的问题解决了吗
已经解决了,用下论坛里的大佬的1path
GMT+8, 2025-12-20 04:41 , Processed in 0.014920 second(s), 3 queries , Gzip On, Redis On.
