楼主: 来了了事
[求助] Hspice仿真环形振荡器电路,无法起振
 楼主| 发表于 2024-3-29 21:18:30 | 显示全部楼层
WESHUO 发表于 2024-3-29 20:46
你把工作点结果发出来看看,网表也一起发出来吧。
* E:\LTspice folders\pre_RO1.asc
.include"e:/Hspicefolders/model/PTM/180nm_bulk.pm"
.options post=2 list
*M1 N1 Vi P001 Vdd PMOS l=1u w=4u
M2 N002 N002 Vdd Vdd PMOS l=0.5u w=4u
M4 N1 N1 0 0 NMOS l=0.5u w=2u
M6 N006 N1 0 0 NMOS l=0.5u w=2u
R1 Vdd N1 10k
M5 N002 N1 0 0 NMOS l=0.5u w=2u
M3 N003 N002 Vdd Vdd PMOS l=0.5u w=4u
XXTG1 N003 Vdd N004 Ctrl1n OUT tg
XXTG2 N004 Vdd N006 OUT Ctrl1n tg
XXSMIT N004 Vdd N005 schmitt_trigger
C1 N004 0 10pf
XXAND N005 EN Vdd OUT and1
XXINV OUT Vdd Ctrl1n inv2
V1 Vdd 0 3.3
*V2 Vi 0 pwl(10P 0 100P 1)
V3 EN 0 1
* block symbol definitions
.subckt tg IN Vdd OUT Ctrln Ctrl
M1 OUT Ctrln IN Vdd PMOS l=0.5u w=2u
M2 IN Ctrl OUT 0 NMOS l=0.5u w=2u
.ends tg
.subckt schmitt_trigger IN Vdd Output
M2 N1 IN N1 N1 PMOS l=0.5u w=3u
M5 N1 IN N4 N4 NMOS l=0.5u w=3u
M4 N4 IN 0 0 NMOS l=0.5u w=3u
M3 0 N1 N1 Vdd PMOS l=0.5u w=3u
M6 N4 N1 Vdd 0 NMOS l=0.5u w=3u
M1 N1 IN Vdd Vdd PMOS l=0.5u w=3u
M7 N1 N001 Vdd Vdd PMOS l=0.5u w=16u
M8 N1 N001 0 0 NMOS l=0.5u w=8u
M9 N001 N1 Vdd Vdd PMOS l=0.5u w=16u
M10 N001 N1 0 0 NMOS l=0.5u w=8u
M11 Output N001 Vdd Vdd PMOS l=0.5u w=16u
M12 Output N001 0 0 NMOS l=0.5u w=8u
.ends schmitt_trigger
.subckt and1 A B Vdd OUT
XX1 A B Vdd N001 nand1
XX2 N001 Vdd OUT inv2
.ends and1
.subckt inv2 IN Vdd OUT
MP1 OUT IN Vdd Vdd PMOS l=0.5u w=4u
MN0 OUT IN 0 0 NMOS l=0.5u w=2u
.ends inv2
.subckt nand1 A B Vdd Out
MN1 Out A N001 N001 NMOS l=0.5u w=2u
MN2 N001 B 0 0 NMOS l=0.5u w=2u
MP1 Out A Vdd Vdd PMOS l=0.5u w=4u
MP2 Out B Vdd Vdd PMOS l=0.5u w=4u
.ends nand1
.tran 1p 20u
.end
发表于 2024-3-30 08:23:34 | 显示全部楼层
WESHUO 发表于 2024-3-29 19:23
你好,个人想法是两个反相器形成正反馈环路,可以快速使得输入快速翻转。因为振荡器我接触很少,如果这个 ...
这种结构的电路,往往振荡不起来,要么是增益不够,要么是到高地电平的时候,某些管子电压关断了,环路分析那一套就失效了
发表于 2024-3-30 10:28:38 | 显示全部楼层
yangleiqiang 发表于 2024-3-30 08:23
这种结构的电路,往往振荡不起来,要么是增益不够,要么是到高地电平的时候,某些管子电压关断了,环路分 ...
受教了,这个电路在刚仿真的时候,确实因为电路工作点的问题,电路无法起振,即使起振,也有可能像你说的那样某些管子电压关断了。
 楼主| 发表于 2024-4-1 09:01:02 | 显示全部楼层
WESHUO 发表于 2024-3-30 10:28
受教了,这个电路在刚仿真的时候,确实因为电路工作点的问题,电路无法起振,即使起振,也有可能像你说的 ...
搭建的电路图是这样的
总电路图
总电路图
TG
TG
施密特
施密特
发表于 2024-4-1 09:54:16 | 显示全部楼层
来了了事 发表于 2024-4-1 09:01
搭建的电路图是这样的
给电容C1一个初始电压0V,还能起振吗?或者强制让电容C1接地,看输出是不是为vdd。
 楼主| 发表于 2024-4-1 10:30:35 | 显示全部楼层
我设置.ic V(N004)=0,起振了;那实际应用中,能这样实际赋初值起振吗
GMT+8, 2025-12-16 14:58 , Processed in 0.017008 second(s), 4 queries , Gzip On, Redis On.
