查看: 1484|回复: 4
vcs问题
发表于 2024-3-15 00:45:59 | 显示全部楼层 |阅读模式
Cannot find a 64-bit simulation kernel
  Cannot find a 64-bit simulation kernel for this platform.
  Please check VCS_HOME is set correctly. Also, check whether you have a
  Full64 VCS version installed. For assistance please contact vcs technical
  support at vcs_support@synopsys.com or call 1-800-VERILOG
发表于 2024-3-15 07:53:22 | 显示全部楼层
确定装了64bit的版本吗?
发表于 2024-3-15 09:40:59 | 显示全部楼层
不知道您vcs的版本,猜测是只安装了linux,没装linux64
vcs_vxxxx.xx-xxx_common.spf
vcs_vxxxx.xx-xxx_linux64.spf
vcs_vxxxx.xx-xxx_linux.spf
 楼主| 发表于 2024-3-16 12:03:02 | 显示全部楼层
是的 少下载了一个
发表于 2024-3-17 03:50:40 | 显示全部楼层
思慕悟言 发表于 2024-3-16 12:03
是的 少下载了一个
so, download 64bit and install
GMT+8, 2025-12-25 18:57 , Processed in 0.014296 second(s), 4 queries , Gzip On, Redis On.
