查看: 1271|回复: 2
[求助] Tessent initial sequence
发表于 2024-3-14 17:03:02 | 显示全部楼层 |阅读模式
由于iopad限制,需要特定的initial sequence来做mbist mode entry,这个sequence刚好要通过iJTAG端口,产生pattern时报错:
//  Error: 'GPIO[6]' is an element of an active scan interface. It cannot be used as an argument of the 'iForcePort' command.
请教高手如何能解决?谢谢
发表于 2024-6-19 16:15:43 | 显示全部楼层
这个sequence你是怎么做的,用了AdvancedOptions吗?
 楼主| 发表于 2024-6-20 13:40:13 | 显示全部楼层
AdvancedOptions的哪个?
GMT+8, 2025-12-19 15:07 , Processed in 0.348711 second(s), 3 queries , Gzip On, Redis On.
