查看: 972|回复: 0
Ploblem with installation GoldenGate 2020
发表于 2024-3-13 03:43:19 | 显示全部楼层 |阅读模式
Origin from   http://bbs.eetop.cn/forum.php?mod=viewthread&tid=868133&fromuid=52691
Run script
setenv CDS_Netlisting_Mode Analog
setenv CDS_LOAD_ENV CSF
setenv CDSHOME /tools/IC618320
setenv XPEDION /tools/GoldenGate-2020
setenv XPEDION_CADENCE_VERSION 618
cd $XPEDION/Licensing/2019.02/linux_x86_64/bin
./lmgrd -c $XPEDION/license.lic -L /home/user/Documents/log.txt
setenv AGILEESOFD_LICENSE_FILE 23111@localhost
setenv CDS_LIC_FILE /tools/license/license_2300_2.dat
setenv PATH "${PATH}CDSHOME/tools/dfII/binCDSHOME/tools/bin"
cd /home/user/Cadence_PROJECTS/install_test
virtuoso
Return
Executing: mccontrol ne600_DC.gg -ggparser -no_parallel -m amap -A ../psf -sim_output_file work -O 2 -o ne600_DC.gg.expanded.gg -I /home/user/Cadence_PROJECTS/install_test -I .
mccontrol GoldenGate-2020 (Sun 2019/09/01 15:48:40 UTC) (C) Keysight Technologies 2007-2019
Control program with pid 53748 started at 'Tue Mar 12 15:41:14 2024'.
ggparser GoldenGate-2020 (Sun 2019/09/01 15:48:40 UTC) (C) Keysight Technologies 2007-2019
Parser started at Tue Mar 12 15:41:14 2024 (PID=53756).
Selecting SiMKit implementation:
Using the Single SiMKit implementation.
Checking out a bundle license (will retry for up to one hour).
Bundle license check out time: 0.011436 second(s).
Checking out a parser license (will retry for up to one hour).
Parser license check out time: 0.00784421 second(s).
Output cache directory: /home/user/.xpedion/cache/ahdl/
Error: Parse error after column 13. Found unexpected token ':'. (amap/designData.json:1) [104.1]
Error: Parse error after column 27. Found unexpected token '1'. (amap/designData.json:1) [104.1]
Error: Parse error after column 28. Found unexpected token ','. (amap/designData.json:1) [104.1]
Error: Parse error after column 29. Found unexpected token '"'. (amap/designData.json:1) [104.1]
Error: Parse error after column 32. Found unexpected token ':'. (amap/designData.json:1) [104.1]
Error: Parse error after column 33. Found unexpected token '{'. (amap/designData.json:1) [104.1]
Error: Parse error after column 34. Found unexpected token '"'. (amap/designData.json:1) [104.1]
Error: Parse error after column 41. Found unexpected token ':'. (amap/designData.json:1) [104.1]
Error: Parse error after column 42. Found unexpected token '{'. (amap/designData.json:1) [104.1]
Warning: 10 instances of message [104.1] have already been printed;
         further instances of this message are being suppressed
Fatal: Errors during parsing. Cannot continue. [105.7]
/tools/GoldenGate-2020/linux_x86_64/bin/ggsim: Parsing failed.
GMT+8, 2025-12-25 19:20 , Processed in 0.011605 second(s), 3 queries , Gzip On, Redis On.
