查看: 1106|回复: 0
模数转换器 SIG5534A 国产平替 CS5534AS
发表于 2024-3-11 17:44:17 | 显示全部楼层 |阅读模式
信格勒微电子的芯片产品已通过行业头部大厂导入验证,深受百万终端客户好评。
而且因为 fully compatible. 板子拿来,换个芯片,性能更好。MCU 不用改 c code。
SIG5531A/SIG5532A/SIG5533A/SIG5534A
1.6SPS to 3840SPS 16-bit/24-bit ADC with PGA and Reference
Compatible Parts
CS5531AS/CS5532AS/CS5533AS/CS5534AS pin/register fully compatible (15nV/℃ and 2ppm/℃).
Features
  • Programmable Gain:   1/2/4/8/16/32/64
  • Data Rates: 1.6SPS to 3840SPS
  • RMS Noises: 16nV at 7.5SPS (Gain = 64)
  • 24.0ENOB (22.3 noise-free bits) at 7.5SPS (Gain= 1)
  • Offset Drift: 5nV/℃ (Gain = 64)
  • Gain Drift: 0.5ppm/℃
  • Integral Non-linearity: 3ppm
  • Reference input current: 250nA
  • Internal Reference: 5ppm/℃
  • Internal or External Clock
  • SINC3/SINC1 Filter Option
  • 2/4 Differential Inputs
  • Current: 5.0mA
  • Specified Temperature Range: -40℃ to 125℃
  • Package: 20/24-ld TSSOP
  • Power Supply
AVDD:
4.75V to 5.25V or ±2.5V
DVDD:
2.7V to 5.25V
Applications
  • Weight Scales and Strain Gauges
  • Flow/Pressure Measurement
  • Temperature Measurement
  • Industrial Process Control
  • Medical Instrumentation
GMT+8, 2025-12-22 23:29 , Processed in 0.016067 second(s), 4 queries , Gzip On, Redis On.
