查看: 1980|回复: 6
[求助] 求助下载三篇RFIC2023工业界最佳论文
发表于 2024-2-23 10:48:22 | 显示全部楼层 |阅读模式
A 14-nm Low-Cost IF Transceiver IC with Low-Jitter LO and Flexible Calibration Architecture for 5G FR2 Mobile Applications
https://ieeexplore.ieee.org/document/10186127
A 28nm CMOS Dual-Band Concurrent WLAN and Narrow Band Transmitter with On-chip Feedforward TX-to-TX Interference Cancellation Path for Low Antenna-to-Antenna Isolation in IoT Devices
https://ieeexplore.ieee.org/document/10186192
A Wi-Fi Tri-band switchable Transceiver with 57.9fs-RMS-jitter Frequency Synthesizer, Achieving -42.6dB EVM floor for EHT320 4096-QAM MCS13 signal
https://ieeexplore.ieee.org/document/10186200
谢谢!
发表于 2024-2-23 14:12:40 | 显示全部楼层
thanks
发表于 2024-2-23 15:30:28 | 显示全部楼层
请查看
A_Wi-Fi_Tri-band_switchable_Transceiver_with_57.9fs-RMS-jitter_Frequency_Synthes.pdf
694.23 KB, 下载次数: 31 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A_28nm_CMOS_Dual-Band_Concurrent_WLAN_and_Narrow_Band_Transmitter_with_On-chip_F.pdf
1.34 MB, 下载次数: 30 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A_14-nm_Low-Cost_IF_Transceiver_IC_with_Low-Jitter_LO_and_Flexible_Calibration_A.pdf
1.52 MB, 下载次数: 35 , 下载积分: 资产 -2 信元, 下载支出 2 信元
回复 支持 2 反对 0
 楼主| 发表于 2024-2-23 17:40:32 | 显示全部楼层
谢谢!
发表于 2024-9-26 21:10:11 | 显示全部楼层
kan kan
发表于 2024-9-26 21:54:56 | 显示全部楼层
Thanks!!!
发表于 2024-9-26 23:47:35 | 显示全部楼层
kan kan
GMT+8, 2025-12-28 09:36 , Processed in 0.439753 second(s), 4 queries , Gzip On, Redis On.
