查看: 1612|回复: 2
[求助] bash: input_db: command not found...
发表于 2024-2-1 15:32:15 | 显示全部楼层 |阅读模式
QRC提寄生中,
Calibre Database Query
This is the directory specified in the query command (query_cmd) file. All the output data of the Calibre query will be written to this directory. This directory will also be specified later in the QRC command file with the input_dbcommand:
  1. input_db -type calibre -directory_name
    复制代码
但是输入显示,bash: input_db: command not found...
 楼主| 发表于 2024-2-1 15:34:35 | 显示全部楼层
如图
 楼主| 发表于 2024-2-4 11:26:02 | 显示全部楼层
已解决,不是一个指令,要在脚本里
GMT+8, 2025-12-21 21:02 , Processed in 0.014948 second(s), 4 queries , Gzip On, Redis On.
