查看: 9236|回复: 40
synopsys 2018 eda tools
发表于 2024-1-20 17:25:20 | 显示全部楼层 |阅读模式
供新手学习:下载完成后解压直接使用,软件是在RHEL8.2 上安装的,软件版本如下:
iceda_tools/
├── cadence
│   ├── ic618_040
│   ├── innovus20
│   │   ├── Base_INNOVUS20.10.000_lnx86.sdp
│   ├── license
│   │   └── license.dat
│   └── spectre21
│       ├── Base_SPECTRE21.10.058_lnx86.sdp
├── siemens
│   ├── calibre2021
│   │   ├── aoi_cal_2021.2_28.15
│   ├── license
│   │   └── license.dat
└── synopsys
    ├── fm
    │   └── 2018.06-SP1
    ├── icc
    │   └── O-2018.06-SP1
    ├── icc2
    │   └── O-2018.06-SP1
    ├── lc
    │   └── O-2018.06-SP1
    ├── license
    │   ├── Synopsys_backup.dat
    │   └── Synopsys.dat
    ├── pts
    │   └── O-2018.06-SP1
    ├── scl
    │   └── 2018.06
    ├── spyglass
    │   └── SPYGLASS2018.09-SP1
    ├── starrc
    │   └── O-2018.06-SP1
    ├── syn
    │   └── O-2018.06-SP1
    ├── vcs
    │   └── O-2018.09-SP2
    ├── verdi
    │   └── Verdi_O-2018.09-SP1
    └── wv
        └── O-2018.09-SP2
软件收集与本论坛,仅供学习之用。如有商业用途,请联系相关厂商。
下面是我的环境设置,请参考(注意软件路径,请按照你的实际解压路径更改)
######################### id design  tools environmet variables  ##############################################
###################  synopsys  ##################################
alias lms='/home/workstation/iceda_tools/synopsys/scl/2018.06/linux64/bin/lmgrd -c /home/workstation/iceda_tools/synopsys/license/Synopsys.dat'
alias lmd='/home/workstation/iceda_tools/synopsys/scl/2018.06/linux64/bin/lmdown -c /home/workstation/iceda_tools/synopsys/license/Synopsys.dat'
export SYNOPSYS="/home/workstation/iceda_tools/synopsys/syn/syn/O-2018.06-SP1"
export SNPSLMD_LICENSE_FILE=27000@workstation
export SNPS_LICENSE_FILE="/home/workstation/iceda_tools/synopsys/license/Synopsys.dat"
######################  dc_shell_2018 ############################
export DC_HOME=/home/workstation/iceda_tools/synopsys/syn/O-2018.06-SP1
export PATH=$SC_HOME/binPATH
alias dc='$DC_HOME/bin/dc_shell'
alias dv='$DC_HOME/bin/design_vision'
######################     lc_2018    ############################
export LC_HOME=/home/workstation/iceda_tools/synopsys/lc/O-2018.06-SP1
export PATH=$LC_HOME/binPATH
export PATH=$LC_HOME/linux64/lc/binPATH
alias lc_shell='$LC_HOME/bin/lc_shell'
#######################   icc_2018     ############################
export ICC_HOME=/home/workstation/iceda_tools/synopsys/icc/O-2018.06-SP1
export PATH=$ICC_HOME/bin:$PATH
alias icc='$ICC_HOME/bin/icc_shell'
alias iccg='$ICC_HOME/bin/icc_shell -gui'
######################## icc2_2018 ################################
export ICC2_HOME=/home/workstation/iceda_tools/synopsys/icc2/O-2018.06-SP1
export PATH=$ICC2_HOME/bin:$PATH
alias icc2='$ICC2_HOME/bin/icc2_shell'
alias icc2g='$ICC2_HOME/bin/icc2_shell -gui'
########################   pts_2018   #############################
export PT_HOME=/home/workstation/iceda_tools/synopsys/pts/O-2018.06-SP1
export PATH=$PT_HOME/bin:$PATH:
export PATH=$PT_HOME/amd64/bin:$PATH
alias pt='$PT_HOME/bin/pt_shell'
alias ptg='$PT_HOME/bin/pt_shell -gui'
########################   fmv_2018   #############################
export FM_HOME=/home/workstation/iceda_tools/synopsys/fm/2018.06-SP1
export PATH=$FM_HOME/bin:$PATH
alias fm='$FM_HOME/bin/fm_shell'
alias fmg='$FM_HOME/bin/fm_shell -gui'
########################   verdi_2018   ############################
export NV_HOME=/home/workstation/iceda_tools/synopsys/verdi/Verdi_O-2018.09-SP1
export PATH=$NV_HOME/bin:$PATH
alias verdi='$NV_HOME/bin/verdi'
export LD_LIBRARY_PATH=$NV_HOME/share/PLI/VCS/LINUX64:$LD_LIBRARY_PATH
########################   satrrc_2018  ############################
export STRC_HOME=/home/workstation/iceda_tools/synopsys/starrc/O-2018.06-SP1
export PATH=$STRC_HOME/bin:$PATH
alias strg='$STRC_HOME/bin/StarXtract -gui'
alias strc='$STRC_HOME/bin/StarXtract'
########################   wv_2018  ############################
export WV_HOME=/home/workstation/iceda_tools/synopsys/wv/O-2018.09-SP2
export PATH=$WV_HOME/bin:$PATH
export PATH=$WV_HOME/platforms/amd64/bin:$PATH
alias wv='$WV_HOME/bin/wv'
########################   vcs_2018   #############################
export VCS_ARCH_OVERRIDE=linux
export VCS_TARGET_ARCH=amd64
export VCS_HOME=/home/workstation/iceda_tools/synopsys/vcs/O-2018.09-SP2
export PATH=$VCS_HOME/bin:$PATH
export PATH=$VCS_HOME/amd64/bin:$PATH
alias vcs='$VCS_HOME/bin/vcs'
alias dve='$VCS_HOME/bin/dve'
export LD_LIBRARY_PATH=$VCS_HOME/amd64/lib:$LD_LIBRARY_PATH
#####################  spyglass_2018   #############################
export SPYGLASS_HOME=/home/workstation/iceda_tools/synopsys/spyglass/SPYGLASS2018.09-SP1/SPYGLASS_HOME
export PATH=$SPYGLASS_HOME/bin:$PATH
export PATH=$SPYGLASS_HOME/lib:$PATH
alias sg='$SPYGLASS_HOME/bin/spyglass'
##################### cadence eda tools envrionment variable ################
####################### ic618 ##############################################
export CDS_AUTO_64BIT="ALL"
export IC618_HOME=/home/workstation/iceda_tools/cadence/ic618_040
export PATH=$IC618_HOME/tools/bin:$PATH
export PATH=$IC618_HOME/tools/dfII/bin:$PATH
export CDS_LIC_FILE=/home/workstation/iceda_tools/cadence/license/license.dat
export LM_LICENSE_FILE=/home/workstation/iceda_tools/cadence/license/license.dat
export LD_LIBRARY_PATH=$IC618_HOME/tools/lib:$PATH
alias ic618='$IC618_HOME/bin/virtuoso'
###################### innovus21 ############################################
export INV_HOME=/home/workstation/iceda_tools/cadence/innovus20
export PATH=$INV_HOME/tools.lnx86/dfII/bin:$PATH
export PATH=$INV_HOME/tools.lnx86/bin:$PATH
export PATH=$INV_HOME/bin:$PATH
######################## SPECTRE21 ##########################################
export SPC_HOME=/home/workstation/iceda_tools/cadence/spectre21
export PATH=$SPC_HOME/tools/bin:$PATH
export PATH=$SPC_HOME/tools/dfII/bin:$PATH
alias spc='$SPC_HOME/bin/spectre'
###################### siemens #############################################
##################### calibre2021 ##########################################
export USE_CALIBRE_VCO=aoi
export CBR_HOME=/home/workstation/iceda_tools/siemens/calibre2021/aoi_cal_2021.2_28.15
export PATH=$CBR_HOME/bin:$PATH
export MGC_LIB_PATH=$CBR_HOME/lib:$PATH
export MGLS_LICENSE_FILE=/home/workstation/iceda_tools/siemens/license/license.dat
alias  cbr='$CBR_HOME/bin/calibre'
alias  cbrg='$CBR_HOME/bin/calibre -gui'
########################## end eda tools ###################################
解压后,运行软件会提示错误,请参考下面的解决方法:
CentOS/RHEL 8.2 install EDA tools
base software package
yum install ksh tcsh csh -y
yum install tcl tk tcl-devel tk-devel -y
libmng.so.1
if centos 7
error while loading shared libraries: libmng.so.1: cannot open shared object file: No such file or directory
such yum install libmng -y
if centos 8
cd /lib64
ll libmng.so.*
sudo ln -s libmng.so.2 libmng.so.1
libXss.so.1
error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
sudo yum install libXScrnSaver -y
libtiff.so.3
error while loading shared libraries: libtiff.so.3: cannot open shared object file: No such file or directory
cd /lib64
ll libtiff.so.*
sudo ln -s libtiff.so.5 libtiff.so.3
libncurses5
sudo yum -y install libncurses*
ld-linux.so.2
/lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
sudo yum install glibc.i686 -y
libXp.so.6
error while loading shared libraries: libXp.so.6: cannot open shared object file: No such file or directory
sudo yum install libXp -y
libGLU.so.1
error while loading shared libraries: libGLU.so.1: cannot open shared object file: No such file or directory
sudo yum install mesa-libGLU
lsb_release
ERROR: Unable to find 'lsb_release'
sudo yum install redhat-lsb -y
libX11.so.6 no such file or directory
libX11.so.6: cannot open shared object file: No such file or directory
sudo yum -y install libX11.i686 libX11-devel.i686
sudo yum -y install libX11.x86_64 libX11-devel.x86_64
libXext.so.6 no such file or directory
error while loading shared libraries: libXext.so.6: cannot open shared object file: No such file or directory
sudo yum -y install libXext.i686 libXext.x86_64 libXext-devel.i686 libXext-devel.x86_64
ZLIB_1.2.9 not found
.../icc2/O-2018.06-SP1/linux64/nwtn/bin/icc2_exec: .../icc2/O-2018.06-SP1/linux64/nwtn/bin/../shlib/libz.so.1: version `ZLIB_1.2.9' not found (required by /lib64/libpng16.so.16)`
need rebuild libpng16 to reduce version
build & install gcc 6.5.0
build & install libpng16
eda2018_tools.rar (159 Bytes , 下载次数: 438 )
发表于 2024-1-20 18:32:35 | 显示全部楼层
Goooood.....................
Thank you very very much...
发表于 2024-1-20 18:36:33 | 显示全部楼层
感谢分享
发表于 2024-1-20 20:05:02 | 显示全部楼层
kanaksndas
发表于 2024-1-20 21:37:43 | 显示全部楼层
多谢分享
发表于 2024-1-20 21:43:54 | 显示全部楼层
看看
发表于 2024-1-21 02:57:19 | 显示全部楼层
thanks
发表于 2024-1-21 05:40:57 | 显示全部楼层
厉害~~~~
发表于 2024-1-21 10:46:50 | 显示全部楼层
多谢分享
发表于 2024-1-21 12:53:44 | 显示全部楼层
good stuff
GMT+8, 2025-10-17 05:54 , Processed in 0.036266 second(s), 4 queries , Gzip On, Redis On.
