查看: 2522|回复: 7
[求助] cadence仿真振荡器,如何能加速起振?
发表于 2024-1-12 11:25:35 | 显示全部楼层 |阅读模式
请教一下大家!
后仿起振太慢了要振3天,但如果用于动态totem的后仿,我不关心起振过程,只关心最终的稳定下来的那一段,有没有一种方法,能够模糊起振过程从而加速起振呢?
发表于 2024-1-12 14:57:11 | 显示全部楼层
transient options form -> misc tab. -> additionalParams
linearic=yes oscfreq=<actual_oscillator_freq>
https://community.cadence.com/ca ... crystal-oscillators
发表于 2024-1-12 15:04:42 | 显示全部楼层
SET initial voltage to the VCO internal nodes.  .ic .... you can also lower your simulator accuracy setting for the start up .
发表于 2024-1-12 15:34:25 | 显示全部楼层
给个transient noise
发表于 2024-1-12 21:01:45 | 显示全部楼层
也可以试试用一个开关先把振荡器环路里面的某个低电容节点(比如某些逻辑门的输入)拉到某个固定点位(比如地),这时由于电路中没有高频振动节点,电源上电和其他偏置电路的电压建立到稳定就会快很多,等这些节点都充分建立后再断开开关,振荡器通常会很快进入最终的稳态。
 楼主| 发表于 2024-1-16 17:27:20 | 显示全部楼层
aznsj 发表于 2024-1-12 15:04
SET initial voltage to the VCO internal nodes.  .ic .... you can also lower your simulator accuracy  ...
i dont know about vco, mine is the crystal osc. you can see the red arrow pointing, i set initial voltage but they are changed at 0~50us.
i think maybe i need to set more and more initial voltage node?
 楼主| 发表于 2024-1-16 17:31:06 | 显示全部楼层
thanks ,the content on the official is exciting, but i failed. i will check the setting. thanks again.
 楼主| 发表于 2024-1-16 17:35:33 | 显示全部楼层
eelin 发表于 2024-1-12 15:34
给个transient noise
谢谢,但是这个似乎没有用呀。
GMT+8, 2025-12-22 12:12 , Processed in 0.033826 second(s), 3 queries , Gzip On, Redis On.
