查看: 1557|回复: 1
[全新] 模数转换器 SIG5532B 国产平替 CS5532BS
发表于 2023-12-14 10:23:19 | 显示全部楼层 |阅读模式
信格勒微电子的芯片产品已通过行业头部大厂导入验证,深受百万终端客户好评。而且因为 fully compatible. 板子拿来,换个芯片,性能更好。MCU不用改 c code。
SIG5532B / SIG5534B
1.6SPS to 3840SPS 32-bit ADC with PGA and Reference
Compatible Parts
CS5532BS/CS5534BS pin/register fully compatible (15nV/℃ and 2ppm/℃).
Features
  • Programmable Gain:   1/2/4/8/16/32/64
  • Data Rates: 1.6SPS to 3840SPS
  • RMS Noises: 11nV at 7.5SPS (Gain = 64)
  • 26.0ENOB (23.4 noise-free bits) at 7.5SPS (Gain= 1)
  • Offset Drift: 5nV/℃ (Gain = 64)
  • Gain Drift: 0.5ppm/℃
  • Integral Non-linearity: 3ppm
  • Reference input current: 500nA
  • Internal Reference: 5ppm/℃
  • Internal or External Clock
  • SINC3/SINC1 Filter Option
  • 2/4 Differential Inputs
  • Current: 5.0mA
  • Specified Temperature Range: -40℃ to 125℃
  • Package: 20/24-ld TSSOP
  • Power Supply
AVDD:
4.75V to 5.25V or ±2.5V
DVDD:
2.7V to 5.25V
Applications
  • Weight Scales and Strain Gauges
  • Flow/Pressure Measurement
  • Temeprature Measurement
  • Industrial Process Control
  • Medical Instrumentation
 楼主| 发表于 2023-12-14 10:24:35 | 显示全部楼层
平替Cirrus Logic芯片
SIG5532B 平替 CS5532BS(32-bit)
SIG5534B 平替 CS5534BS(32-bit)
SIG5532A 平替 CS5532AS(24-bit)
SIG5534A 平替 CS5534AS(24-bit)
SIG5530 平替 CS5530 (24-bit)
SIG5530B 平替 CS5530(32-bit)
平替ADI芯片
SIG7792 平替 AD7792
SIG7793 平替 AD7793
SIG7794 平替 AD7794
SIG7795 平替 AD7795
SIG7796 平替 AD7796
SIG7797 平替 AD7797
SIG7798 平替 AD7798
SIG7799 平替 AD7799
平替TI芯片
SIG1230A 平替 ADS1230 (20-bit)
SIG1232A 平替 ADS1232 (24-bit)
平替ADI芯片
SIG7190 平替 AD7190
SIG7192 平替 AD7192
SIG7193 平替 AD7193
GMT+8, 2025-12-12 04:52 , Processed in 0.014043 second(s), 5 queries , Gzip On, Redis On.
