查看: 10157|回复: 43
[求助] skill脚本求助—给器件加label
发表于 2023-11-23 16:51:14 | 显示全部楼层 |阅读模式
求助,请问有适用cadence IC5141里面xl调出器件之后,一键给器件加对应label的skill脚本吗?
 楼主| 发表于 2023-11-23 16:58:37 | 显示全部楼层
procedure(CreateLabelXL()
let((cv objs origin name label)
cv = geGetEditCellView()
objs = cv ~> instances
foreach(obj objs
origin = centerBox(obj~>bBox)
name = obj ~> name
label = dbCreateLabel(cv list("TXT" "ttxt") origin name "centerCenter" "R0" "roman" 0.2)
leAttachFig(label obj)
);foreach
);let
);proc
hiSetBindKey("Layout" "<Key>KP_3" "CreateLabelXL()")
以上的一个脚本是从论坛找到的,我试了load没有报错,但是实际快捷键没有反应。
发表于 2023-11-23 17:08:00 | 显示全部楼层
这一句改成name = obj ~> cellName
发表于 2023-11-23 17:58:00 | 显示全部楼层
应该是baseName吧
发表于 2023-11-23 17:59:16 | 显示全部楼层
618 自带这个功能
发表于 2023-11-23 21:04:48 | 显示全部楼层
maomao198477 发表于 2023-11-23 17:59
618 自带这个功能
能不能详细说说,或者搜索这个功能的关键词,数字连接几十个label打的奔溃了,
发表于 2023-11-24 09:56:59 | 显示全部楼层
L,然后直接选中需要的器件
回复 支持 3 反对 0
发表于 2023-11-24 14:15:32 | 显示全部楼层
roceduce: "Auto Create M1 and  GT_via on MOS"
;Function: Press "<Key>3" to auto create M1(S/D) GT&CT
;Version: V2.0
;Created by XiangLi on  20/6/2023.
;Bug:
hiSetBindKey("Layout" "<Key>3" "addM1_gt_via()")
procedure(addM1_gt_via()
        let((cv tech viaID sels sel tran shapes shape temp1 points start end x0t y0t x1t y1t tempAA bBox  center_point y0 y1 tempGT bBox_GT n0 n1 new_GT NEWVIASGate NEWVIASSource)
                ;Auto Create Vias in area
                TechFile=techGetTechFile(geGetEditRep())
                CGroupID=cstFindConstraintGroupIn(TechFile "virtuosoDefaultSetup")
                MyViaOptions=viaGetViaOptions(CGroupID)
                MyViaOptions~>automatic~>minNuMCUts=2
                cv=geGetEditCellView()
                tech=techGetTechFile(cv)
                viaID=techFindViaDefByName(tech "M1_GT")
                viaID12=techFindViaDefByName(tech "M2_M1")
                viaID23=techFindViaDefByName(tech "M3_M2")
                sels=geGetSelSet()
                foreach(sel sels
                                if(sel~>objType == "inst"
                                        then tran=sel~>transform
                                                 center_point=centerBox(sel~>bBox)
                                                 dbCreateLabel(cv list("TXT" "ttxt") center_point sel~>name "centerCenter" "R0" "roman" 0.4)
                                                 shapes=sel~>master~>shapes
                                                foreach(shape shapes
        if(shape~>lpp == list("M1" "drawing")
        then temp=dbCopyFig(shape cv tran)
        temp1=leConvertPolygonToPath(temp)
        temp1~>width=0.11
        tempm2=dbCopyFig(shape cv tran)
        tempm2=leConvertPolygonToPath(tempm2)
        tempm2~>width=0.11
        tempm2~>lpp=list("M2" "drawing")
        tempm3=dbCopyFig(shape cv tran)
        tempm3=leConvertPolygonToPath(tempm3)
        tempm3~>width=0.11
        tempm3~>lpp=list("M3" "drawing")
        points=temp1~>points
        start=nth(0 points)
        end=nth(1 points)
        x0t=xCoord(start) y0t=yCoord(start)
        x1t=xCoord(end)  y1t=yCoord(end)
        dbDeleteObject(temp1)
        dbCreatePath(cv "M1" list((x0t:y0t-0.025) (x1t:y1t+0.025)) 0.11)
        dbDeleteObject(tempm2)
        dbCreatePath(cv "M2" list((x0t:y0t-0.025) (x1t:y1t+0.025)) 0.11)
        dbDeleteObject(tempm3)
        dbCreatePath(cv "M3" list((x0t:y0t-0.025) (x1t:y1t+0.025)) 0.11)
        NEWVIASSource=viaGenerateViasInArea(cv list((x0t:y0t-0.025) (x1t:y0t-0.025) (x1t:y1t+0.025) (x0t:y1t+0.025)) MyViaOptions)
        ) ;end if
        if(shape~>lpp == list("AA" "drawing")
        then
        tempAA=dbCopyFig(shape cv tran)
        bBox=tempAA~>bBox
        y0=bottomEdge(bBox)
        y1=topEdge(bBox)
        dbDeleteObject(tempAA)
                                                               ) ;end ifNEWVIASGate
                                                if(shape~>lpp == list("GT" "drawing")
        then
        tempGT=dbCopyFig(shape cv tran)
        bBox_GT=tempGT~>bBox
        n0=leftEdge(bBox_GT)
        n1=rightEdge(bBox_GT)
        dbDeleteObject(tempGT)
                                  ) ;end foreach
        new_GT=dbCreateRect(cv "GT" list((n0:y0-0.1) (n1:y1+0.21)))
        newm1=dbCreateRect(cv "M1" list((n0+0.065:y1+0.1) (n1-0.065:y1+0.21)))
        newm1=leConvertPolygonToPath(newm1)
        newm2=dbCreateRect(cv "M2" list((n0+0.065:y1+0.1) (n1-0.065:y1+0.21)))
        newm2=leConvertPolygonToPath(newm2)
        NEWVIASGate=viaGenerateViasInArea(cv list((n0+0.065:y1+0.1) (n1-0.065:y1+0.1) (n1-0.065:y1+0.21) (n0+0.065:y1+0.21)) MyViaOptions)
        NEWVIASSource=viaGenerateViasInArea(cv list((x0t:y0t) (x1t:y0t) (x1t:y1t) (x0t:y1t)) MyViaOptions)
                                            ) ;end if
                           ) ;end foreach
        ;         newm1=dbCreateRect(cv "M1" list((n0:y1+0.11) (n1:y1+0.23)))
        ;         newm1=leConvertPolygonToPath(newm1)
        ;         newm2=dbCreateRect(cv "M2" list((n0:y1+0.11) (n1:y1+0.23)))
        ;         newm2=leConvertPolygonToPath(newm2)
给你一个我写的脚本, 作用给选中的管子加label 以及给管子源漏上加金属线打孔,gate上加线打孔~ 写的不太好 应该能用
回复 支持 2 反对 0
发表于 2023-11-24 14:17:57 | 显示全部楼层
支持smic40工艺,其他工艺下需要改一下参数吧
发表于 2023-11-24 14:29:43 | 显示全部楼层
gybak 发表于 2023-11-24 14:15
roceduce: "Auto Creat ...
感谢,我来试试哈
GMT+8, 2025-12-28 19:26 , Processed in 0.026988 second(s), 6 queries , Gzip On, Redis On.
