查看: 2932|回复: 12
[资料] 博士论文
发表于 2023-11-9 14:05:27 | 显示全部楼层 |阅读模式
With the ever increasing bandwidth demand in high performance computing, network and communications, machine learning applications, etc, wireline data transfer between multiple chips on the same package has been doubling in per-lane data rate every 3-4 years. The challenging design complexity of the analog and mixed signal front-end circuits necessitates the use of automated process portable layout generators and closed loop design scripts to reduce the turn-around time from circuit design to tape-outs in advanced FinFET technology nodes. To that end, this thesis introduces new feature improvements in the Berkeley Analog Generator (BAG) 3++, which is an open source framework for automating process portable circuit generation and encoding closed loop design methodologies. Then the thesis presents the design of a 160 Gbps NRZ transmitter (TX) targeting low loss ( 3dB) ultra short reach channels for die-to-die data transfer, with 2 tap FFE for pre-equalization. Some major challenges in this effort are the design of a high speed 8:1 mux stage using inductor-based peaking topologies, and a novel method of creating the 1 UI delayed data stream for the FFE precursor using the available octature clock phases. The TX is taped out in Intel16 process as a part of a complete 160 Gbps NRZ transceiver design, and tested in loopback mode by serially transmitting data to the receiver over a 8.5 mm differential channel on package.
Biswas_2023_Design Methodologies and Automated Generation of Ultra High Speed Wireline.pdf
14.55 MB, 下载次数: 86 , 下载积分: 资产 -5 信元, 下载支出 5 信元
Design Methodologies and Automated Generation of Ultra High Speed Wireline SerDes Transmitters
发表于 2023-11-9 14:26:20 | 显示全部楼层
发表于 2023-11-10 06:12:41 | 显示全部楼层
Thanks
发表于 2023-11-10 08:05:45 | 显示全部楼层
160G NRZ的TX还是挺厉害的,对电感的处理,对4:1电路的描述都学到了不少
发表于 2023-11-10 08:34:58 | 显示全部楼层
先赞后看,好运不断!!!
发表于 2023-11-10 09:06:26 | 显示全部楼层
Thanks for sharing.
发表于 2023-11-10 10:01:19 | 显示全部楼层
Thanks!!!
发表于 2023-11-10 20:34:32 | 显示全部楼层
多谢分享
发表于 2023-11-10 23:24:07 | 显示全部楼层
多谢分享。。
发表于 2023-11-10 23:44:08 | 显示全部楼层
kankan
GMT+8, 2025-12-21 15:41 , Processed in 0.020433 second(s), 4 queries , Gzip On, Redis On.
