查看: 1893|回复: 3
[求助] 求助关于AddPinToFloatingWire.il
发表于 2023-11-7 17:14:47 | 显示全部楼层 |阅读模式
悬赏200资产未解决
请教大佬们,我先用schHiCreateWireStubs() create wires to symbol,然后选中wire线再用这个脚本发现没有创建Pin,是在哪出问题呢?
  1. /* abAddPinToFloatingWire.il
  2. Author     A.D.Beckett
  3. Group      Custom IC (UK), Cadence Design Systems Ltd.
  4. Language   SKILL
  5. Date       Dec 02, 2020
  6. Modified
  7. By
  8. Add a pin to any selected floating wire. Usage:
  9. abAddPinToFloatingWire()
  10. abAddPinToFloatingWire(?direction "input")
  11. The default is to add inputOutput pins unless the ?direction
  12. is specified
  13. ***************************************************
  14. SCCS Info: @(#) abAddPinToFloatingWire.il 12/02/20.10:59:59 1.1
  15. */
  16. /********************************************************************
  17. *        *
  18. *         abAddPinToFloatingWire([?direction "inputOutput"]         *
  19. *                      [?pinUsage "schematic"]                      *
  20. *                      [?wires geGetSelSet()]                       *
  21. *                                 )                                 *
  22. *        *
  23. *   Take the selected wires (or wires passed in) and add pins to    *
  24. *  the floating end of that wire, based on the net information on   *
  25. *   the wire. The pin direction can be specified as an argument,    *
  26. *  and the pins to use are looked up using schPinMasters (the same  *
  27. * as the schematic editor create pin command uses to seed the form) *
  28. *        *
  29. ********************************************************************/
  30. procedure(abAddPinToFloatingWire([url=home.php?mod=space&uid=316438]@key[/url] (direction "input") (orientation "R90")
  31.         (pinUsage "schematic")
  32.         (wires geGetSelSet()))
  33.     let((netName cvId pinUnderneath pinOptions pinMasterInfo offsheet
  34.             pinMaster wireUnderneath)
  35.         ;----------------------------------------------------------------
  36.         ; Determine the pin master to use given the direction
  37.         ; and pinUsage (normally schematic)
  38.         ;----------------------------------------------------------------
  39.         offsheet=cadr(assoc(pinUsage car(schPinMasters)))
  40.         pinOptions=foreach(mapcar (usageInfo pinInfo)
  41.                 car(schPinMasters)
  42.                 cddr(assoc(direction schPinMasters))
  43.             cons(car(usageInfo) pinInfo)
  44.         )
  45.         pinMasterInfo=cdr(assoc(pinUsage pinOptions))
  46.         if(pinMasterInfo then
  47.             pinMaster=dbOpenCellViewByType(
  48.                 car(pinMasterInfo) cadr(pinMasterInfo) caddr(pinMasterInfo)
  49.             )
  50.             unless(pinMaster
  51.                 error("Could not open pin master %L\n" pinMasterInfo)
  52.             )
  53.         else
  54.             error("Could not find pin master for direction %L usage %L\n"
  55.                 direction pinUsage)
  56.         )
  57.         ;----------------------------------------------------------------
  58.         ; Determine cellView to create in from one of the wires
  59.         ;----------------------------------------------------------------
  60.         cvId=car(wires)~>cellView
  61.         ;----------------------------------------------------------------
  62.         ; Visit each wire and check that it's actually a wire (in case you
  63.         ; have selected other things on the schematic
  64.         ;----------------------------------------------------------------
  65.         foreach(wire wires
  66.             when(wire~>objType=="line" || wire~>objType=="path"
  67.                 netName=wire~>net~>name
  68.                 if(netName then
  69.                     foreach(point wire~>points
  70.                         pinUnderneath=dbShapeQuery(
  71.                             cvId
  72.                             "pin"
  73.                             list(point point)
  74.                         )
  75.                         ;------------------------------------------------
  76.                         ; Find any wires underneath that aren't this wire
  77.                         ;------------------------------------------------
  78.                         wireUnderneath=setof(
  79.                             shapeUnderneath
  80.                             dbShapeQuery(
  81.                                 cvId
  82.                                 "wire"
  83.                                 list(point point)
  84.                                 0
  85.                                 0
  86.                             )
  87.                             shapeUnderneath!=wire
  88.                         )
  89.                         unless(pinUnderneath || wireUnderneath
  90.                             schCreatePin(
  91.                                 cvId
  92.                                 pinMaster
  93.                                 netName
  94.                                 direction
  95.                                 offsheet
  96.                                 point
  97.                                 orientation
  98.                             )
  99.                         )
  100.                     )
  101.                 else
  102.                     warn("Selected wire does not have net name yet\n")
  103.                 )
  104.             )
  105.         )
  106.         dbClose(pinMaster)
  107.         t
  108.     )
  109. )
  110. hiSetBindKey( "Schematics" "<Key>F7" "abAddPinToFloatingWire()")
  111.
    复制代码
abAddPinToFloatingWire_V2.txt
4.87 KB, 下载次数: 8 , 下载积分: 资产 -2 信元, 下载支出 2 信元
售价: 1 信元资产  [记录]
发表于 2023-11-16 14:07:06 | 显示全部楼层
适当print一些重要的中间结果看看?
 楼主| 发表于 2023-11-16 16:44:19 | 显示全部楼层
dugucloud 发表于 2023-11-16 14:07
适当print一些重要的中间结果看看?
好的, 谢谢
发表于 2025-7-9 21:55:51 | 显示全部楼层
感谢分享
GMT+8, 2025-10-20 22:59 , Processed in 0.019614 second(s), 5 queries , Gzip On, Redis On.
