查看: 3842|回复: 11
[求助] 求助IEEE论文
发表于 2023-10-26 22:33:13 | 显示全部楼层 |阅读模式
悬赏400资产已解决
1、A Low-Noise Area-Efficient Column-Parallel ADC With an Input Triplet for a 120-dB High Dynamic Range CMOS Image Sensor
doi:https://doi.org/10.1109/TVLSI.2023.3323363
2、A 12.5-ppm/°C 1.086-nW/kHz Relaxation Oscillator with Clock-Gated Discrete-Time Comparator in 22nm CMOS Technology
doi:https://doi.org/10.1109/ESSCIRC59616.2023.10268752
3、A 0-to-35mA NMOS Capacitor-Less LDO with Dual-Loop Regulation Achieving 3ns Response Time and 1pF-to-10nF Loading Range
doi:https://doi.org/10.1109/ESSCIRC59616.2023.10268699
4、A 1.9μVrms 7.7ppm/°C ADC Reference with 20mA Output Current and Single-Trim Inaccuracy of ±0.03%(3σ) from -40°C to 125°C
doi:https://doi.org/10.1109/ESSCIRC59616.2023.10268754
5、An 18.2μW 101.1dB DR Fully-Dynamic ΔΣ ADC with Partially-Feedback Noise-Shaping Quantizer and CLS-Embedded Two-Stage FIAs
doi:https://doi.org/10.1109/ESSCIRC59616.2023.10268800
6、A linearity improvement method for CIS column-parallel SAR ADC using two-step conversion
doi:https://doi.org/10.1109/ESSCIRC59616.2023.10268814
最佳答案
发表于 2023-10-26 22:33:14 | 显示全部楼层
Here:
A linearity improvement method for CIS column-parallel SAR ADC using two-step co.pdf (707.55 KB , 下载次数: )
An 18.2μW 101.1dB DR Fully-Dynamic ΔΣ ADC with Partially-Feedback Noise-Shapi.pdf (945.97 KB , 下载次数: )
A 1.9μVrms 7.7ppm°C ADC Reference with 20mA Output Current and Single-Trim Ina.pdf (1.12 MB , 下载次数: )
A 0-to-35mA NMOS Capacitor-Less LDO with Dual-Loop Regulation Achieving 3ns Resp.pdf (1.09 MB , 下载次数: )
A 12.5-ppm°C 1.086-nWkHz Relaxation Oscillator with Clock-Gated Discrete-Time C.pdf (780.28 KB , 下载次数: )
A Low-Noise Area-Efficient Column-Parallel ADC With an Input Triplet for a 120-d.pdf (3.04 MB , 下载次数: )
发表于 2023-10-27 08:45:23 | 显示全部楼层
Here:
发表于 2023-10-27 08:53:35 | 显示全部楼层
大赞
发表于 2023-10-27 09:54:42 | 显示全部楼层
thanks
发表于 2023-10-27 16:11:03 | 显示全部楼层
先赞后下
发表于 2023-10-27 16:14:04 | 显示全部楼层
兄台,怎么可以下到这些papers>??
发表于 2023-10-27 16:40:19 | 显示全部楼层
发表于 2023-10-30 19:42:24 | 显示全部楼层
thanks
发表于 2023-10-31 17:44:56 | 显示全部楼层
1. 進入iEEE. 找到文件對應的 DOI
2. 進入 SCI-HUB.ST , 輸注DOI
GMT+8, 2025-12-22 11:32 , Processed in 0.020615 second(s), 6 queries , Gzip On, Redis On.
