查看: 3375|回复: 3
[求助] ic617 关于仿真模型未定义的报错
发表于 2023-10-19 11:07:56 | 显示全部楼层 |阅读模式
"input.scs" 23: The instance `I3' is referencing an undefined model or subcircuit, `subcircuit'. Either include the file containing the definition of `subcircuit', or define `subcircuit' before running the simulation.Warning from spectre during hierarchy flattening
发表于 2023-10-19 11:54:18 来自手机 | 显示全部楼层
q一下I3这个器件,看报错信息是它的model name有问题,指定的model name在你的model里面没有,所以报错说模型未定义
发表于 2024-7-12 19:08:56 | 显示全部楼层
楼主又找到解决的方法吗?
发表于 2024-11-21 16:07:12 | 显示全部楼层
请问解决了没?
GMT+8, 2025-11-16 15:53 , Processed in 0.212740 second(s), 3 queries , Gzip On, Redis On.
