发表于 2024-6-26 09:04:33
显示全部楼层
cAbstract—This paper presents a capacitor-less low dropout
(LDO) regulator that requires no frequency compensation, with
the use of an adaptive-deadzone ring amplifier. Due to the
dynamic behavior of the ring amplifier depending on the input
voltage, the proposed LDO features a hybrid (digital or analog)
operation and achieves both fast transient response and high
output accuracy with a low quiescent current. Moreover, an
adaptive deadzone biasing scheme is employed to ensure high
stability for a wide range of load current operating conditions. A
1V LDO prototype with 80mA maximum load current is
implemented in a 0.18m CMOS process, consuming only a
quiescent current of 6.5A with a dropout voltage of 90mV. It
achieves 172−432ns settling time for load current transitions
between 1mA and 81mA. The active area is 0.1mm2.
