查看: 3541|回复: 11
[求助] 求一个完整的redhawk Generic_tutorial (别名RH_Lite_Training)实验
发表于 2023-9-16 19:30:51 | 显示全部楼层 |阅读模式
有哪位大佬有redhawk Generic_tutorial (别名RH_Lite_Training)实验
是包含以下完整目录的文件,整个文件应该是大几百MB的。
应该有如下文件夹 design_data;static_run;dynamic_run;scripts;fao;low_power;CPM;early_analysis;signalEM;vcd_run;package_run; esd_run;Excel2IR;
The directory GENERIC_tutorial contains
      GENERIC_tutorial
          |--> design_data --> Contains designs specific inputs given to Redhawk
          |      |--> def --> Contains the def files for the design
          |      |--> lef --> Contains the lef files for the design
          |      |--> lib --> Contains the .lib for the design
          |      |--> apl
          |      |      |--> stdcells_apl --> Contains the cell.current file
          |      |      |--> stdcells_aplcap --> Contains the cell.cdev file
          |      |      |--> stdcells_aplpwcap --> Contains the cell.pwcap and decap_cell.pwcap file
          |      |      |--> switch.model
          |      |--> ploc --> Contains the pad location file
          |      |--> timing --> Contains the timing file containing Slew and Timing window information
          |      |--> spf --> Contains the spef file for the design
          |      |--> gds2def --> Contains the def and lef files for the gds2def macros
          |      |--> tech --> Contains the technology file.
          |      |--> vcd --> Contains the input vcd file.
          |      |--> package --> Contains package file
          |      |--> esd --> Cotains esd rule files and std cell list
          |--> static_run
          |      |--> setup.csh --> Script to set APACHEROOT, PATH and LM_LICENSE_FILE.
          |      |--> run_static.tcl --> Command file for the static run
          |      |--> GENENRIC.gsr --> GSR file pointing to all input files and also containing some preset variables
          |--> dynamic_run
          |      |--> run_dynamic.tcl --> Command file for the static run
          |--> scripts --> Contains perl scripts to generate switch voltage and switch current histograms
          |      |--> plot_switch_histogram1.pl*
          |      |--> plot_switch_histogram2.pl*
          |      |--> plot_switch_histogram3.pl*
          |      |--> plot_switch_histogram4.pl
          |      |--> align_waveforms.pl - Script for unit conversion and presim alignments.
          |--> fao          |        |--> dynamic_mesh_optimize - Contains the Tcl script to run mesh_optimize
          |        |--> dynamic_mesh_optimize_taper - Contains the Tcl script to run mesh_optimize
          |        |--> dynamic_mesh_fix - Contains the Tcl script to run mesh_optimize
          |        |--> dynamic_mesh_sub_grid - Contains the Tcl script to run mesh_optimize
          |        |--> dynamic_decap_remove - Contains the Tcl script to run decap_remove
          |        |--> dynamic_decap_fill - Contains the Tcl script to run decap_fill
          |--> low_power
          |     |--> Mixed mode analysis. Contains the Tcl and gsc file
          |--> CPM
          |     |--> cpm_run - CPM creation in RedHawk. Contains the gsr and tcl file
          |     |--> power_transient_mode
          |     |--> resonance_aware_mode
          |     |--> user_configurable_mode
          |     |--> icpm
          |--> early_analysis
          |     |--> lab1
          |       |--> static_prototype - An experiment to analyze the IR impact. Contains gsr,gsc and the run tcl file
          |       |--> dynamic_prototype - An experiment to analyze the IR impact. Contains gsr,gsc and the run tcl file
          |--> signalEM -Contains the command file and GSR file for a signalEM run
          |--> vcd_run - Contains the run tcl and GSR file for the worst power and worst dvd cycle runs
          |--> package_run - Contains the dircetories for the run with RCLK package & S-paramter package
          |--> esd_run - Contains the README and run directories for esd anlayis runs
          |--> Excel2IR - Contains the required files to run the Excel2IR flow
发表于 2023-9-17 17:34:44 | 显示全部楼层
怎么看不到
 楼主| 发表于 2023-9-18 14:10:09 | 显示全部楼层
stockwang 发表于 2023-9-17 17:34
怎么看不到
看不到什么
发表于 2023-9-22 13:48:47 | 显示全部楼层
https://pan.baidu.com/s/1xk4N1Sc8pDFiBGlgBzbbfQ?pwd=2023
share from eetop:
https://bbs.eetop.cn/thread-445492-1-1.html
But! Not include below list:
fao
CPM
early_analysis
signalEM
vcd_run
package_run
esd_run
Excel2IR
发表于 2023-9-25 20:15:07 | 显示全部楼层
GENERIC_tutorial 和RH_Lite_Training是两个lab,后一个是简化版的
前一个是全些的,可以在https://bbs.eetop.cn/forum.php?m ... p;highlight=redhawk下载
发表于 2023-9-26 09:33:41 | 显示全部楼层
GENERIC_tutorial
下载的training lab内容不全啊,少了一些
https://bbs.eetop.cn/forum.php?m ... ;page=7#pid10866017
发表于 2023-9-26 19:28:33 | 显示全部楼层
share from eetop:
THANYOU
 楼主| 发表于 2023-9-26 22:30:12 | 显示全部楼层
前一个是全些的,可以在https://bbs.ee ...
我早就下载过了,但是还是不全,想求一个全的!
 楼主| 发表于 2023-9-26 22:31:33 | 显示全部楼层
xiexie57 发表于 2023-9-26 09:33
GENERIC_tutorial
https://bbs.eetop.cn/forum.php?mod=viewthre ...
是的,GENERIC_tutorial比RH_Lite全一点,但是也是一个不完整的lab,我需要的是完整的lab
发表于 2024-4-30 11:01:47 | 显示全部楼层
完整的lab有了吗?同求啊
回复 支持 0 反对 1
GMT+8, 2025-9-16 21:50 , Processed in 0.017803 second(s), 3 queries , Gzip On, Redis On.
