查看: 1578|回复: 1
[讨论] icc布局布线时创建power straps时blocked的警告怎么解决
发表于 2023-9-13 17:28:31 | 显示全部楼层 |阅读模式
请问下大家,最近在跑ICC的流程,我在创建power straps时,用的命令是
create_power_straps -direction vertical \
                    -configure step_and_stop \
                    -nets {VDD VSS} \
                    -layer METAL4 \
                    -width 1.5 \
                    -start_at 15 -step 30 -stop ${core_urx} -pitch_within_group 1.8 \
                    -ignore_parallel_targets \
                    -keep_floating_wire_pieces
然后出现了好多blockage的警告,Warning: wire dropped because obstruction, ((196.250 4.975) (197.670 5.255)) (Net: VSS) (Layer: METAL3 [28]) is blocked by ((3.500 3.500) (246.180 5.000)) (Net: VDD) (Layer: METAL3 [28]). (PGRT-030)
Warning: wire dropped because obstruction, ((224.375 244.045) (225.625 245.295)) (Net: VDD) (Layer: METAL3 [28]) is blocked by ((224.375 243.850) (225.625 244.390)) (Net: VDD) (Layer: METAL3 [28]). (PGRT-030)
Warning: wire dropped because obstruction, ((226.250 4.975) (227.670 5.255)) (Net: VSS) (Layer: METAL3 [28]) is blocked by ((3.500 3.500) (246.180 5.000)) (Net: VDD) (Layer: METAL3 [28]). (PGRT-030)
类似这样的警告,请问下这样该怎么处理呢
发表于 2024-5-11 20:34:55 | 显示全部楼层
老哥,我也遇到了这个问题 请问你解决没
GMT+8, 2025-9-17 13:19 , Processed in 0.022305 second(s), 3 queries , Gzip On, Redis On.
