查看: 2088|回复: 2
SIG5532B 国产替代 CS5532BS
发表于 2023-8-29 11:22:09 | 显示全部楼层 |阅读模式
pin/register fully compatible. MCU 不用改 c code,板子拿来,换个芯片,性能更好。
SIG5532B / SIG5534B
1.6SPS to 3840SPS 32-bit ADC with PGA and Reference
Compatible Parts
CS5532BS/CS5534BS pin/register fully compatible (15nV/℃ and 2ppm/℃).
Features
Programmable Gain:   1/2/4/8/16/32/64
Data Rates: 1.6SPS to 3840SPS
RMS Noises: 11nV at 7.5SPS (Gain = 64)
26.0ENOB (23.4 noise-free bits) at 7.5SPS (Gain= 1)
Offset Drift: 5nV/℃ (Gain = 64)
Gain Drift: 0.5ppm/℃
Integral Non-linearity: 3ppm
Reference input current: 500nA
Internal Reference: 5ppm/℃
Internal or External Clock
SINC3/SINC1 Filter Option
2/4 Differential Inputs
Current: 5.0mA
Specified Temperature Range: -40℃ to 125℃
Package: 20/24-ld TSSOP
Power Supply
AVDD :4.75V to 5.25V or ±2.5V
DVDD : 2.7V to 5.25V
Applications
Weight Scales and Strain Gauges
Flow/Pressure Measurement
Temeprature Measurement
Industrial Process Control
Medical Instrumentation
 楼主| 发表于 2023-9-16 12:16:39 | 显示全部楼层
华秋商城
    型号: SIG5532B-ITSP20-RL
    描述: 2通道, 1.6SPS至3840SPS, 32位ADC, 带超低噪声PGA和低温漂基准
3+             ¥57.2
10+           ¥50.6
100+        ¥46.2
500+        ¥44
 楼主| 发表于 2023-8-31 19:15:43 | 显示全部楼层
信格勒微电子的芯片产品已通过行业头部大厂导入验证,深受百万终端客户好评。
SIG5532B 所有性能指标均达到甚至超过 CS5532BS,而且因为pin/register fully compatible. 所以 MCU 不用改 c code,板子拿来,换个芯片,性能更好。
系列产品包括
SIG5532B 国产替代 CS5532BS(32-bit)
SIG5534B 国产替代 CS5534BS(32-bit)
SIG5532A 国产替代 CS5532AS(24-bit)
SIG5534A 国产替代 CS5534AS(24-bit)
SIG5530 国产替代 CS5530 (24-bit)
SIG5530B 国产替代 CS5530(32-bit)
GMT+8, 2025-12-21 06:59 , Processed in 0.016079 second(s), 6 queries , Gzip On, Redis On.
