查看: 3302|回复: 7
[求助] candence的ams仿真错误
发表于 2023-8-25 10:23:37 | 显示全部楼层 |阅读模式
悬赏200资产未解决
在candence的ams仿真里出现irun: *E,ELBERR: Error during elaboration (status 2), exiting错误是什么原因??求解答
 楼主| 发表于 2023-8-25 14:50:42 | 显示全部楼层
(./netlist.vams,60|182): No connection module found:Need an input port of continuous discipline electrical, and an output port of discrete discipline logic, at instance sim_dig_sdm.I0.
具体错误
发表于 2023-8-26 23:06:08 | 显示全部楼层
cpy819 发表于 2023-8-25 14:50
(./netlist.vams,60|182): No connection module found:Need an input port of continuous discipline elec ...
看起来是没设置好connect rule,可以把irun.log 最前面的命令log信息贴出来看看?
 楼主| 发表于 2023-8-28 17:19:02 | 显示全部楼层
maximum error count reached (50).
ncelab: Memory Usage - 49.0M program + 185.6M data = 234.6M total (Peak 234.6M)
ncelab: CPU Usage - 0.3s system + 0.1s user = 0.4s total (0.5s, 85.5% cpu)
irun: *E,ELBERR: Error during elaboration (status 2), exiting.
TOOL:        irun(64)        15.20-p001: Exiting on Aug 28, 2023 at 10:48:50 CST  (total: 00:01:19)
是这个吗
 楼主| 发表于 2023-9-1 14:19:55 | 显示全部楼层
求回复
 楼主| 发表于 2024-10-9 11:34:23 | 显示全部楼层
发表于 2024-12-25 22:03:16 | 显示全部楼层
大佬,我也遇到这问题了,有解决吗
发表于 2025-2-13 14:05:11 | 显示全部楼层
GMT+8, 2025-11-17 08:12 , Processed in 0.018728 second(s), 3 queries , Gzip On, Redis On.
