查看: 1047|回复: 0
[讨论] IBIS-AMI die s-parameter
发表于 2023-6-20 14:48:33 | 显示全部楼层 |阅读模式
RX's die s-parameter
These s-parameter files model the load from the receiver input Pad to the input of the AFE stage, it includes the receiver termination.
TX's die s-parameter
These s-parameter files model the load from the transmitter main driver output to the die Pad, it includes all the parasitics from routing, ESD, T-coil.
GMT+8, 2025-10-15 03:48 , Processed in 0.009812 second(s), 3 queries , Gzip On, Redis On.
